spark plug diagnosis - JeepForum.com
post #1 of 32 Old 08-02-2009, 07:38 PM Thread Starter
cloiselle
any one see anything in particular going on inside my engine from these plugs i just pulled ( 08-02-09 )
ngk 6987 copper v powers came out and champion copper oem's went in.
i would like to think it's " normal " but anyone with more experience, and legitimate experience. please chime in.
cloiselle is offline
post #2 of 32 Old 08-02-2009, 07:42 PM
jeep0312
look pretty normal too me! at least i hope! i just changed mine that looked similar in color
-Travis-
2004 Chevy Malibu, red, 2.2 ecotec, shiny wheels, loud stereo
2000 Suzuki SV650N, V-twin, Yoshimura Exhaust, Custom Rashed Paint Job...
jeep0312 is offline
post #3 of 32 Old 08-02-2009, 08:25 PM
vansskaterfreek
normal... they didn't even look that worn...
1998 ZJ 5.9L 122k miles - DD, 242 swap, 3.5" RE, 32" BFG M/T, safari rack, roof-mounted lights, custom steel front bumper with hitch reciever, 10k winch :)
2004 WJ 4.7L 107k miles - her daily driver, 2" daystar BB with scorpion shocks.. not too bad! stuffed 265/65/17 General Grabber AT2'S
vansskaterfreek is offline
post #4 of 32 Old 08-02-2009, 08:29 PM Thread Starter
cloiselle
i was starting to see a drop in mpg and throttle response, changed the plugs, cleaned the airbox and amsoil filter and cleaned my throttle body. back to normal again
i only run plugs 20k miles. for $16, why not.
post #5 of 32 Old 08-02-2009, 09:00 PM
malibubts
They look just fine. If I had to say anything worn, but they are far from from it.
Eric - '02 Laredo Grand Cherokee
Build Thread
malibubts is offline
post #6 of 32 Old 08-02-2009, 11:01 PM
Kruzin
Kruzin's Avatar
They look to be in great shape.
Not worth replacing.
Lots of miles left on them.
DD/Wheeler: 98 ZJ 5.2, 4.5" on 33s
DD/Wifeys: 00 XJ, stock
Weekend toy: 13 Challenger R/T Blacktop
Kruzin is offline
post #7 of 32 Old 08-02-2009, 11:22 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Originally Posted by cloiselle View Post
[IMG]ngk 6987 copper v powers came out and champion copper oem's went in
Probably a downgrade. Why are you messing with the plugs in the first place?
HighLonesome is offline
post #8 of 32 Old 08-02-2009, 11:26 PM Thread Starter
cloiselle
quite an upgrade, mpg , throttle response up, operating temp's down.
ngk copper v's are the same thing as any regular copper core plug, they just have a v slotted into the electrode which does nothing, google psychosomatic.
post #9 of 32 Old 08-02-2009, 11:27 PM Thread Starter
cloiselle
oh hell, i know right.
WHY BOTHER WITH BASIC MAITENENCE.
not like i want to get the best life and efficiency out of my vehicle anyways,
that care crap is garbage
i hear the greatest stuff online.
post #10 of 32 Old 08-02-2009, 11:32 PM
HighLonesome
carry on soldier
post #11 of 32 Old 08-03-2009, 05:26 AM
kentman
kentman's Avatar
2006 XK Commander
The manual recommends 30K on plugs. You should not need to do them sooner than that. If you choose to go shorter than the recommendation, then when do you stop. 20K is probably better than 30K. 15K should be better than 20K. 10K has to be better than 15K. I just go with the manual numbers.
If the part looks horrible at the manual recommendation, then I shorten the interval the next time until I find something that works. I do the same thing on extensions from the manual. If the part looks perfect at the manual recommendation, then I will decide the next time if I want to extend things. Timing belts are a good example. The manual recommends 50K miles, but I let it ride to about 70K miles. Timing belt jobs are a major pain.
Also, since you did multiple things, it is hard to tell which is the source of performance improvement. The cleanings may have done it, and the plugs may have done nothing.
'06 XK Limited, 5.7L, QD II, Black, 150K
'02 WJ Overland, 4.7L HO, QD, Inferno Red, 115K
kentman is offline
post #12 of 32 Old 08-03-2009, 08:19 PM
vansskaterfreek
i have always put the champions in my jeeps, thats what it calls forfrom the factory, thats what goes in it.... i always run the champions...at like $2 a plug you cannot beat that
post #13 of 32 Old 08-03-2009, 08:23 PM
rooster51
my zj gets bi-polar and Terets Syndrom if I run anything other than cheap Champions or Autolites.
rooster51 is offline
post #14 of 32 Old 08-03-2009, 09:51 PM
wickerham
autolites in everything i've ever run...all the way
wickerham is offline
post #15 of 32 Old 08-03-2009, 11:18 PM Thread Starter
cloiselle
i did see some peculiar behavior at the end of those ngk's run.
odd startup, lack of throttle response and a drop in mpg. like i've said, i think the oem part is the way to go although i went with a different champion plug , same heat range and core though. almost the same
WJ Spark Plug Diagnosis & Replacement (w/ pics) mailforjon WJ Grand Cherokee Forum 36 02-15-2012 04:46 PM
spark plug gap mbquart ZJ Grand Cherokee Forum 8 09-01-2009 09:16 PM
WJ spark plug help joee0914 ZJ Grand Cherokee Forum 4 01-09-2009 12:39 PM
Spark plug effort level & plug recomendations Bville-Bud WK Grand Cherokee & XK Commander Forum 3 11-26-2008 01:02 PM
spark plug help me! TheAngus ZJ Grand Cherokee Forum 3 09-20-2006 07:33 PM
