spark and fuel no start? - Page 2 - JeepForum.com
post #16 of 56 Old 01-23-2013, 07:46 PM Thread Starter
xrunndonex
1994 ZJ
Originally Posted by ratmonkey View Post
check the spark with an actual plug. you need to know if it's getting a hot enough spark and the screwdriver trick won't tell you that.
also, check that the injectors are pulsing properly. are all the plugs fuel fouled?
ok getting the plug in cylinder 1 was easy once I got the boot off wish I had smaller hands but it looked like this
xrunndonex is offline
post #17 of 56 Old 01-23-2013, 07:47 PM Thread Starter
xrunndonex
1994 ZJ
Sorry for the lack if knowledge I'm learning as I go
post #18 of 56 Old 01-23-2013, 08:24 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
it's out of focus but that looks like mechanical damage to the insulator there...pull all the plugs and inspect them. doesn't look like they've been changed in a very long time.
ratmonkey is offline
post #19 of 56 Old 01-23-2013, 09:12 PM Thread Starter
xrunndonex
1994 ZJ
Yea I got it from my Grandpa said he replaced them he got it at about 140k miles I got it at 178kish it's at 215k need to go Jeep shopping soon. And didn't see any damage just alot of build up of ash I got new plugs now need to get wires tomorrow and I'll throw them in I'll let you know where I end up tomorrow.
post #20 of 56 Old 01-24-2013, 02:08 AM Thread Starter
xrunndonex
1994 ZJ
Hey man nice Jeep it's a GC eh? hard to see on the phone how is the mpg with those tires wanting to upgrade mine but still want decent mpg.
post #21 of 56 Old 01-24-2013, 04:43 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Yeah, was on 35" baja claws, 4.5" Clayton long arms, 8.8, 5spd nv3500 trans, 3.73 gears.
Bunch of engine bolt ons.
Gets about 12 combined, it has gotten 11 city, 15hwy since I put 32" bfg at/ko's on it.
Ash isn't a good sign, that usually means a bad head gasket or oil leak.
A tune up might fix your issues, you're well beyond ready.
post #22 of 56 Old 01-24-2013, 04:37 PM Thread Starter
xrunndonex
1994 ZJ
well i went to start it after new plugs and wires and it was really close to starting. i got the right plugs but i guess i can pull the wires off and make shure there on nice some of them are a little sketchy. but the coolent in the resevare just a little dirty last coolent flush i didnt get all the old stuff out completely but it smells like coolent even took some out and no separation not shure if they have the same no bubbles nothing just smells like coolent
so the possibility of not getting enough air or pcm possibly shot or timing off there is a oil leak by the oil filter it isnt the filter its o rings were it connects but inside forgot there name
Guess I'll pressure test the cylinders can anyone point me to a good guide? Incase it is the hg
post #23 of 56 Old 01-26-2013, 03:14 PM Thread Starter
xrunndonex
1994 ZJ
Hey man I re checked the fuel pressure on rail and when I first turn the key it goes at 42 then second later goes to 34ish then goes to 37 idk if it was the gauge but is 37 the end result makes since on why sometimes when it's cranking it will sort of sputter. I don't know what's suppose to be on the rail I know there pumps put out 80
I really want to know why my Jeep dies when it has a full tank.. Everytime replacing it with 25 gallons of ****ing gas oh lord help me sort of hoping someone siphons some.
post #24 of 56 Old 01-26-2013, 04:54 PM
1skrewsloose
Can't say for sure, but, plugs look way different from the plugs for my 98 gc. A lot of porcelain showing, not sure if that means cold or hot plug? If you have spark at the right time and hit the throttle body with starter fluid seems like it should fire up. New wires, cap, rotor, proper gap on plugs?
1skrewsloose is offline
post #25 of 56 Old 01-26-2013, 05:07 PM Thread Starter
xrunndonex
1994 ZJ
Plugs said don't gap and couldn't find the gaper so I went with it. I'll go buy starter fluid do I spray it in there well it's cranking or just spray then crank?
post #26 of 56 Old 01-26-2013, 08:00 PM Thread Starter
xrunndonex
1994 ZJ
Yea idk there autolight platnum or something new ones look like the old ones
post #27 of 56 Old 01-26-2013, 09:46 PM
1slo_camaro
subscribing. i had the same issue, my jeep was running fine. then went into walmart came out and no fire. checked all the dumb stuff did i have gas in the tank. blown fuse blah blah blah.... couldnt figure out. called my old man. we went through it ridiculously! screwdriver in the wire, then a plug in the wire. starting fluid, hell i even sprayed starting fluid directly into the chamber (yes i know its not ideal, but desperate measure) 42 psi of fuel and when you pull the plug and turn the motor over it spits fuel out the hole...... i am kinda kicking myself in the *** for not replacing the coil, but i had a spare motor and jumped the gun and yanked the motor and hopefully tomorrow dropping my dizzy in the spare motor and HOPEFULLY firing it up tomorrow. if not i will replace the coil and see where that puts me..... if not i am starting to give up because myself and my dad (close to 30 years of experience with cars, trucks, boats, diesel, heavy machines... not a dummy lol) but we are completely stumped with it and everything checks out, we have compression (no i didnt test it with a gauge, did the redneck finger trick and it was enough to blow your finger off with force, ive seen low compression motors and high compression...12:1 comp motors. and it felt decent) we have fuel, we have spark..... but no fire.... no fire at all. it doesnt even stumble like it wants to start.
so i look forward to you finding the issue and helping me. or if i can find what happend with mine i will post up and maybe help you out
1998 ZJ~~V.r 4~~4.0 with a bunch of fancy stuff that makes it look pretty sitting in the driveway.
PM me for 99+ intake manifolds for sale
$125-sandblasted and painted and shipped
1slo_camaro is offline
post #28 of 56 Old 01-27-2013, 03:00 AM Thread Starter
xrunndonex
1994 ZJ
Yea I'll tell you if I find something you have the same problem I want to push mine in a river. It's Probly something so small I'm just happy AutoZone has to do returns did you try double or triple priming it? Sometimes that works for people.
post #29 of 56 Old 01-27-2013, 04:21 AM
melk
If everything else appears ok, that leaves the PCM.... have you cleaned the connectors and one of you hold them tight/wiggle them while you crank it?
melk is offline
post #30 of 56 Old 01-27-2013, 04:50 AM Thread Starter
xrunndonex
1994 ZJ
pcm connected to the firewall on passenger side right?
broke , jeep , no start , zj
