spark and fuel no start? - JeepForum.com
post #1 of 56 Old 01-22-2013, 08:45 PM Thread Starter
xrunndonex
1994 ZJ
im stumped my 94 jeep gc larado isnt starting gets gas spark so in the normal world it would start had fuel pressure tested was good full tank. it started when i woke up at 4 in the morning it was cold like 20 degrees and went to start it and it turns over slow dead battery or weak but i got a new one after work got the wrong one posts were on the wrong side they still made it to the posts so i went to it went to fire it up and it just cranks it was running good the night before. and the rotor moves. help please driving the car cant be this low to the ground
I also replaced the alt a week before it didn't start but with the new alt it was always at 14 volts
xrunndonex is offline
post #2 of 56 Old 01-22-2013, 08:48 PM Thread Starter
xrunndonex
1994 ZJ
and its a 6cyl
post #3 of 56 Old 01-22-2013, 10:50 PM
jnicewan
Weak or dead battery might have caused the engine to become flooded, put the throttle to the floor and crank it for a few seconds and see if it starts. It could also be a number of things like an IAC stuck not allowing enough air to bypass for idle, this should at least make it sound like it wants to start, but you might try cleaning it or at least spray a little cleaner in the throttle body. Try this stuff first and let us know.
jnicewan is offline
post #4 of 56 Old 01-23-2013, 10:35 AM
zjosh93
I had a similar problem once, cold snap and wouldn't start not the dead battery. Turned out to be a bad coil. It was bad enough it wouldn't start but still managed to throw an arc when I tested it. I was going through a coil a year back then so I kept a spare under the back seat. Coil failures are generally rare but it seems like the 4.0 coil placement let's them get hot and fail prematurely. Might be worth finding a friend with a 4.0 to try swapping coils with. I upgraded to an MSD coil and made a bracket to move the coil up behind the AC compressor. No bad coils in the last 3 years.
zjosh93 is offline
post #5 of 56 Old 01-23-2013, 10:56 AM
LordHobbit
make sure the rotor button is not broken. Happened to me and took myself many hours and a master technician many hours to figure it out. Most expensive rotor button I ever purchased.
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
post #6 of 56 Old 01-23-2013, 01:23 PM Thread Starter
xrunndonex
1994 ZJ
Isn't that the on top of the rotor that the power from the coil goes to? I have new rotor and cap put a coil in and nothing new happened held the gas down well starting and nothing but whenever I go to start it most of the time it will crank and for a slight second it sounds like it's going to turn over but it don't. I'm going to mess with it later gotta go do family **** now lol
post #7 of 56 Old 01-23-2013, 01:33 PM Thread Starter
xrunndonex
1994 ZJ
It's really clean I clean it every now and then. It has a oil leak and I hear sometimes cars won't start if they have no or little oil could it be that?
post #8 of 56 Old 01-23-2013, 01:34 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
you installed the battery backwards and tried to crank it? sure fire way to kill your pcm there.
ratmonkey is offline
post #9 of 56 Old 01-23-2013, 01:53 PM Thread Starter
xrunndonex
1994 ZJ
No the posts were just on the other side the other one the posts were by the windshield and this one there towards the grill there still on the right posts haha
post #10 of 56 Old 01-23-2013, 02:40 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
how did you check for spark?
how did you check for fuel getting into the cylinders?
does the check engine light come on for 3 seconds at key on?
post #11 of 56 Old 01-23-2013, 03:11 PM
Trick440
1994 ZJ
I'm curious how fuel and spark where tested too. It should start if them are good.
Is the air filter or intake blocked?
Trick440 is offline
post #12 of 56 Old 01-23-2013, 06:51 PM Thread Starter
xrunndonex
1994 ZJ
Had someone come over has a heavily modified civic came with a pressure tester from the rail and you can smell unburned gas in the cylinders when you take plugs out. And wires used a screwdriver to see if there good same with plugs never did check the plug in 1 it's blocked by the a/c. And yes the engine light does come on and goes away in 3 seconds
post #13 of 56 Old 01-23-2013, 06:52 PM Thread Starter
xrunndonex
1994 ZJ
Nope there both good.
post #14 of 56 Old 01-23-2013, 07:30 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
check the spark with an actual plug. you need to know if it's getting a hot enough spark and the screwdriver trick won't tell you that.
also, check that the injectors are pulsing properly. are all the plugs fuel fouled?
post #15 of 56 Old 01-23-2013, 07:38 PM Thread Starter
xrunndonex
1994 ZJ
Alright I'll do that and by fuel foiled you mean smell like gas? I mean I should just go buy some tomorrow how much are wires? I'm sure the stock wires are on it and it has 215k miles ha
broke , jeep , no start , zj
