Spare tire size - JeepForum.com
post #1 of 29 Old 03-27-2013, 10:55 AM Thread Starter
thumper450
Spare tire size
I have a 93 gwagoneer 318 all time 4wheel drive 3.73 w/open diffs. I am running 30-9.50-15 ko's still have original 225/75/15 spare. My next tires will be 31/10.50/15 do I need to match my spare? At least in size.
thumper450 is offline
post #2 of 29 Old 03-27-2013, 11:02 AM
KingtheZJ
yes. with the 249 you want to
'88 XJ
'98 ZJ on 37s and tons
'02 Chevy 2500HD 8.1
KingtheZJ is offline
post #3 of 29 Old 03-27-2013, 12:02 PM
ejschultz
ejschultz's Avatar
Yup, and you probably should have had a matching size spare with the 30s as well. If you're not lifted, you're not getting away without trimming to fit those 31s.
01 TJ - 4.0L, NV3550, 2" Skyjacker budget boost, Trail Gear front bumper, 31" Duratracs on 15x8s
ejschultz is offline
post #4 of 29 Old 03-27-2013, 12:05 PM
PolkaPower
Yes you need 5 matching tires and rotate the spare in with oil changes.
PolkaPower is offline
post #5 of 29 Old 03-27-2013, 02:06 PM Thread Starter
thumper450
I've got a 2" bb lift, 1.25" spacers on the rear and an arb front bumper so I shod be ok on the 31's.
post #6 of 29 Old 03-27-2013, 02:19 PM
dnuccio
Do not even use the stock spare with 30 inch tires. You will destroy the viscous coupler in the transfer case
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #7 of 29 Old 03-27-2013, 02:30 PM Thread Starter
thumper450
Guess I've been lucky the spares never been on the ground. Goodyear invicta blue letters and all
post #8 of 29 Old 03-27-2013, 02:31 PM
ejschultz
ejschultz's Avatar
The stock tire size is a 28.3" tire. FYI.
post #9 of 29 Old 03-28-2013, 03:08 AM
AmishFury
you people with factory full size spares disgust me... i had to go find a rim to get my full size spare
AmishFury is offline
post #10 of 29 Old 03-28-2013, 03:43 AM
KoreaZJ
1994 ZJ
Originally Posted by AmishFury View Post
...i had to go find a rim to get my full size spare
Same here, mine came with a donut spare, luckily never needed to use it. Missed the TSB/recall for 249 TC's for the full size spare.
KoreaZJ is offline
post #11 of 29 Old 03-28-2013, 06:21 AM
98LIZJ
What about using the stock spare with 31x10.5x15 but just not using 4wheel? Still bad?
98LIZJ is offline
post #12 of 29 Old 03-28-2013, 06:44 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
If you have the 249 transfercase yes, that's a bad idea.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #13 of 29 Old 03-28-2013, 08:10 AM
PolkaPower
With a 249 you are always in full time. If you have 2wd then you don't have a 249.
post #14 of 29 Old 03-28-2013, 08:24 AM
98LIZJ
Yea I have the 242. So with those size tires and only in 2wheel the stock spare can still be used?
98LIZJ is offline
post #15 of 29 Old 03-28-2013, 09:57 AM
dnuccio
It could, but I wouldn't do it for an extended period of time. I wouldn't use it any longer than getting to the local tire shop
R.I.P. Ratmonkey
dnuccio is offline
