Spare tire - JeepForum.com
post #1 of 12 Old 03-11-2003, 03:07 PM Thread Starter
ILoveto4x4inNC
Spare tire
I've been told by the dealer and the tire shop that I should replace all the tires at the same time since I have the QuadraTrac. I'm running slightly bigger than stock tires except for the spare which is still the factory 225 75 15. Should I replace the spare on the next tire change? If I do have to use the factory spare between now and the time that I replace the tires (probably in the next couple of months) will it hurt anything? From what I've been told I could screw up the transfer case by running mismatched tires. Is this true? Thanks for the input.
This aint your daddy's Jeep!
'98 ZJ with 5.2L
Stock except for Optima red top
bigger tires(30x9.50 15 BFG MTs)
Rancho RS5000 shocks
swapped in NV231
and Pioneer CD deck.
White Jeep Club member #14
ILoveto4x4inNC is offline
post #2 of 12 Old 03-11-2003, 05:08 PM
Camster
Camster's Avatar
it shouldn't cause any problems. the differential is designed to allow the wheels to spin at different rate, as will happen when running different sized tires. the drive shaft will be spinning like it normaly does and not mess up the transfer case.
Cameron
Camster is offline
post #3 of 12 Old 03-11-2003, 08:39 PM
Camster
Camster's Avatar
if ya drive on the spare for a short distance it will not hurt a thing. for long distance it isn't such a good idea. if ya got to use it the first stop should be a tire space to fix the tire.
Cameron
Camster is offline
post #4 of 12 Old 03-12-2003, 09:25 PM
Swamp Boy
Swamp Boy's Avatar
Ditto Camster, Dont cruise on the spare just put it on and drive to
a tire shop. Thats what spares are for. Unlike people who you see
with a donut spare with the tread worn off going 80 down the interstate..
Just another soccer moms Grocery getter....
Swamp Boy is offline
post #5 of 12 Old 03-21-2003, 08:41 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
If you want to do a much better thing, buy a cheapo beater in the same size of your good four tires.
You don't want to run the risk of messing up the tranny and or axles with mismatched tires.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #6 of 12 Old 12-28-2003, 05:21 AM
JeepZJlover
How messed up
Umm if you guys think about it and pay attention the full size spare tire is a 245/75R/15 Kewords there 245 and 15" first of all the limiteds come with 16" rims and they generally come with 225 tires so dont use the spare IT WILL OVERHEAT THE AXLE
JeepZJlover is offline
post #7 of 12 Old 12-28-2003, 07:29 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
I can't believe you brought this back from the dead.
It is the worst kind of idea to run a mismatched spare on any type of vehicle unless you just HAVE to to get out of something safely. It is way too easy to pick up a same size spare even a bald one to take you from A to B to get the other tire fixed. It always makes me laugh to see guys with 33s or bigger tires and the little donut on back. Like that would get you anywhere!
Hunter
04 4.7 HO, limited
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #8 of 12 Old 12-28-2003, 12:42 PM
Buddha_Kip
Buddha_Kip's Avatar
i think that's only here in New Orleans ....but yeah, they're here in abundance...best is when you see a car broken down on 610 with the donut on and it's the one that blew.
2000 WJ Limited - 2.5" Rusty's springs WAAG 1-piece front brush guard custom built WAAG nerf bars PIAA 580 lighting Custom Paint One-off Aluminum Treadplate Door Entry Guards & Rear Bumper Step
1986.5 Porsche 928S - 18" Moda MD1 Autothority Chips Rear Muffler Bypass Short-Shift Kit
Grease Monkey & HNIC @ Clasik Auto
Buddha_Kip is offline
post #9 of 12 Old 12-28-2003, 05:25 PM
Swamp Boy
Swamp Boy's Avatar
Kip.. Where are you around the CIty?
Why havent you been to any of our Meet and Greets?
Sup?
I like to see them broken down with no tire at all...
I always wonder how in the hell the whole tire came off..
Are they complete idiots?? Cant you feel your tire falling off???
post #10 of 12 Old 12-28-2003, 06:07 PM
Buddha_Kip
Buddha_Kip's Avatar
Sup?
I'm over in Lakeview...on Robert E. Lee. haven't really gotten into this Jeep as I have into my others. 1. It's 2wd and damn heavy and underpowered...i'm kinda scared to take it into the spillway. 2. 1 pretty much explains it. To be honest, I've never seen any other GC's in the area that haven't had a soccer mom behind the wheel. Finally spotted one today back behind the robert's and stuff over there on rbt e lee and west end...white ZJ with ARB front end...didn't really stop. let me know when the next gtg is, i'll make it out.
post #11 of 12 Old 12-30-2003, 01:58 AM
Peter
Peter's Avatar
Um, I have a 94 GC Limited and it has 15"s all around. They are the gold ones that match the trim. It also comes with the same rim as a full size spare.
Peter is offline
post #12 of 12 Old 12-30-2003, 06:00 AM
Meerkat
Mine has 16" wheels all around. However, the spare is a 245/70R15 on a black 5 spoke steel (I think) wheel (similar to the 95 Cherokee wheels). This is a PITA because my cargo cover doesn't fit around the spare. The build sheet calls for a compact spare, but I have no idea what size that is or what it looks like. My current spare was made in 97 is a 60,000 mile tire that has never been driven on (still has paper sticker on tread area). The wheel is as new also. Since I use the spare as intended (to get to a repair facility) and want to maximize cargo space, and use my (perfectly good) tire cover, I am considering trading the one I have for what should go there. Anybody have any information (and pics) that would help me identify the correct part?
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
WJ spare tire, max tire size in back? EarpWJ WJ Grand Cherokee Forum 18 09-08-2010 04:30 PM
Largest tire in spare tire area n8man1068 ZJ Grand Cherokee Forum 7 07-13-2009 01:40 PM
How to use the old spare tire mount on a 31" tire! NickkciN ZJ Grand Cherokee Forum 20 12-19-2008 03:25 PM
What size tire will fit in the spare tire well? ssiders ZJ Grand Cherokee Forum 11 11-07-2006 09:35 PM
Tire size and spare tire canuckJGC ZJ Grand Cherokee Forum 4 10-22-2004 06:06 PM
