Sound system thread for ZJ's - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Sound system thread for ZJ's
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 10-21-2012, 08:43 PM   #16
Edwardmiller221
I installed rockford fosgare component speakers in the front hung two rockford 6x9 in rear, they are in boxes, with a rockford 650 w amp, one 12 inch kicker comp with a 1600 w autotek amp. An Alpine single din head unit. It rocks!
Edwardmiller221 is offline   Reply With Quote Quick reply to this message
Unread 10-21-2012, 08:45 PM   #17
nickpequignot
Currently I have 4 kenwood 3 way speakers I think. Cheap on sale at best buy and sounded better than the pioneers in the same price range. They are on a old kenwood amp have a kenwood kdc248u head unit. Then a fosgate p1 10 on a Jensen 4 ch. 6ga to a distribution block then 8ga to amps. Getting a dc audio level 3 12. Going to get a kicker zx 1000.1 amp for that. 0 gauge power and ground. I'm going to build a center console and put a set of speakers in the front. Both fronts will be on the kenwood. Then get another set of 2 way speakers and put in the back for the back seat and get a set if dash tweeters. The tweets and rear speakers will be on the Jensen. Eventually I am going to do the big 3 and get a wj 4.0 alt, probably run a second battery in line with the power wire untill then.
nickpequignot is offline   Reply With Quote Quick reply to this message
Unread 10-21-2012, 09:09 PM   #18
xtremzj
Alpine 123 head unit
Monster cable
Kappa 6.5
Alpine v12 for the speakers
Alpine v12 for the subs
2 Rockford fosgate 10" subs
From head unit to tail gate is dynamat'ed
98 ZJ 5.5in hybrid long arm/35"TSLs/4.7 Golen Stroker/Kevin's front bumper/TrailReady rear/hp30/d44/4.56/oba/dual battery/rocklights/milemarker9k.Way to much to list.
QuirkWorks Sponsored #44 subaru rally car
CHRYSLER CERTIFIED MASTER TECH. PM IF YOU HAVE QUESTIONS.
xtremzj is offline   Reply With Quote Quick reply to this message
Unread 10-22-2012, 09:13 AM   #19
FAlfani81
Kenwood DDX8017 Double Din
2 Rockford Power T1s on a Rockford Power T1500 amp
2 Rockford Power 6x9 on an old Rampage amp I got for free
4 6.5in Pioneer 4way speakers in the doors.
Amps are on their own Charging system. I removed the A/C and replaced it with a second alternator. I use a Duralast marine battery on a ford explorer alternator. I honestly find that the Duralast marine battery is holding up much better then the Kiniteck 1800s I had and any Yellow or Red top I used lol.
Its all done half assed. I gave up on the system and decided to take care of the more useful aspects of the Jeep.
FAlfani81 is offline   Reply With Quote Quick reply to this message
Unread 10-22-2012, 09:18 AM   #20
nickpequignot
How did you do a 2din?
Unread 10-22-2012, 10:48 AM   #21
nickpequignot
Originally Posted by sculptalot
Which radio wiring harness did you use to wire up your radio. or did you cut into the stock wiring?
I just cut mine off because the zj will never go back to stock.
Unread 10-22-2012, 03:27 PM   #22
FAlfani81
Sawsall grinder, flat head screw driver as a chisel. It doesn't look pretty but it doesn't look bad. I'm eventually going to box off around it to fill in the sides.
As for the rest of the unfinished system that will probably never get finished. Heres the pics for all that.
The cheap little yellow amp for the 6x9s cooked itself. its now replaced with an even cheaper little blue amp
Unread 10-22-2012, 03:29 PM   #23
FAlfani81
UGHH lol, stupid iPhone!! does anyone else have a problem with their photos turning out upside down if they don't edit them every single time?
Unread 10-22-2012, 04:24 PM   #24
spife7980
-James
Got to love an ORVIS guy...
IRO 5.5", Front LA & Double Sheer TB, Rear Adj SA and TB, JKS Quick Discos, Bilstein 5125, 265/75/16 Nitto Terra's, Cragar 16x& Soft 8s 4" bs
JCR Stage 2 Sliders, IRO Trans Skid, Carolina Drive shaft, IRO exhaust
spife7980 is offline   Reply With Quote Quick reply to this message
Unread 10-22-2012, 05:08 PM   #25
FastSUV
I listen to AM talk radio
BUT...I am surprised that these "boom boxes" are still popular? I had Cerwin Vega 12" back in the early 90's Perhaps someday I will upgrade my stereo again; it is "on my list" LOL
ZJ - 5.9 Limited
WJ - '04 4.7 Laredo
WJ - '04 4.7 H.O. Freedom
WJ - '04 Overland
FastSUV is offline   Reply With Quote Quick reply to this message
Unread 10-22-2012, 05:35 PM   #26
nickpequignot
When I drove dads explorer I listened to am talk all the time. But now that I drive my zj again. I listen to my music. And yes these "boom boxes" are vary popular.
Unread 10-22-2012, 05:59 PM   #27
Azalin_00
Baller on a Budget
My Money
My Ears
My Jeep
Azalin_00 is offline   Reply With Quote Quick reply to this message
Unread 10-22-2012, 06:32 PM   #28
nickpequignot
How's come all the crazy big sub boxes never have any carpet on them? Another question. Eventually I'm going to have 6 speakers. Front door speakers. Then probably some 5 1/4 in my front console. Havnt decided on 3 full sets of speakers in the front to keep most sound coming from the front stage. Then a single set in the rear. What do you guys think are some good 2 ways. I have one 4 ch amp that is 65 watts rms per ch at 4 ohm. And I would have to look at my other 4 ch but I think it's a little less. What do you guys think?
Unread 10-22-2012, 06:52 PM   #29
Azalin_00
3 Reasons:
1. People who are serious about car audio go through many different enclosures until finding what works best, so committing to one box is out of the question.
2. We go through different subs, so different subs mean different specs for the enclosure.
3. Most people on the quest to get the most out of their subs, really done care what it looks like as long as it works.
Baller on a Budget
My Money
My Ears
My Jeep
Unread 10-22-2012, 08:49 PM   #30
ejschultz
ejschultz's Avatar
Originally Posted by spife7980 View Post
I love my 1043D. It's a great little sub, if small can describe it. What are specs on that enclosure? I'm guessing its sealed. I have mine in .54 net cubes sealed on 600 RMS.
And I've had 4 different subs in 5 boxes in 2.5 years. Each box was furnished.
97 ZJ - 5.2L, 242, 4" IRO lift w/short arms & adj. TBs, JKS Discos/BPEs, DT3000s, Aussie'd 44A, sliders, OEM skids/hooks/hitch, 31" Duratracs on 15x8s
14 JKU Sport S - Stock
Build
ejschultz is offline   Reply With Quote Quick reply to this message
