Sound system thread for ZJ's - JeepForum.com
post #1 of 90 Old 10-17-2012, 08:20 PM Thread Starter
nick93ZJ
Show your sound system! I have 2 rival 15's in a 4thover band pass box with a kerf port hooked to a massive n2 amp. Switching to 2 smaller audio pipe amps with a shüriken bt35 battery. Going to be about 143 dbs at 37ish hz. Pics soon
..,=====,o00o
//__l_l_,\____\,__
l_---\_l__l---[]lllllll[]
_(o)_)__(o)_)--o-)_)___
nick93ZJ is offline
post #2 of 90 Old 10-17-2012, 08:26 PM
mig1289
That system sounds like it bumps. I have 2 pairs of hifonics components in front and rear running at 150w rms per speaker and a 300w hifonics subwoofer. All this is running of a 900w rms 5 channel amp
2wd zj...
mig1289 is offline
post #3 of 90 Old 10-18-2012, 05:56 PM
JohnC7
Listed is what I have done to my zj:
Big three with 1 gauge copper wire
2 gauge stinger wiring kit
E2 scosche distro block
2 leads of 4 gauge copper to amps
Infinity 475a speaker amp
Hifonics 2000 rms at 1 ohm sub amp
Power acoustik nb-2 dash tweeters
Pioneer mvh-p8200 head unit
Infinity 63.9i front speakers amped
Infinity 6030cs rear speakers HU
MTX ts8512 750 rms wired at 1 ohm
Ported box tuned at 34 hz
JohnC7 is offline
post #4 of 90 Old 10-18-2012, 06:14 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
clarion deck. forget model number
kove audio 6.5 component speakers front
400w ultra audio 2ch amp for the front
2 12" hifonics atlas subwoofers powered by 2 600wrms kenwood amps
ratmonkey is offline
post #5 of 90 Old 10-19-2012, 01:36 PM
Azalin_00
Pioneer Premiere
Big Three with 0 gauge
2 Kinetik Hc1800s
Hifonics components in the front doors
Hifonics full range on back doors
Cheap 4ch amp pushing front stage
Sub Enclosure is 10cu ft tuned to 36hz
2 18" RD Audio Heavyweights
RD Audio D9
Baller on a Budget
My Money
My Ears
My Jeep
Azalin_00 is offline
post #6 of 90 Old 10-19-2012, 01:52 PM
speedbucket
Ran 1-00 to a distribution block in the cargo area
infinity kappas at all 4 corners pushed by an alpine v-12
2 10" kicker 10's (old school ones with the Kevlar surrounds, worked great for working on 8 years) pushed by a jensen 720 2 channel
i ran 3 jl8w3s with a jl mono-block for a year or two and one of the surround deteriorated
highway speeds with windows down and shes clear as a bell, i would recommend kappas to anyone
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #7 of 90 Old 10-19-2012, 03:17 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
i have kappa 6.5 components, 6x9 coax, and 10" sub with a kappa 5ch amp in my spyder.
post #8 of 90 Old 10-19-2012, 03:29 PM
Azalin_00
That's a good SQ setup there.
Baller on a Budget
My Money
My Ears
My Jeep
post #9 of 90 Old 10-19-2012, 03:58 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
it's good. it'd be better if it wasn't a rag top. lol
post #10 of 90 Old 10-19-2012, 09:39 PM
sculptalot
Which radio wiring harness did you use to wire up your radio. or did you cut into the stock wiring?
sculptalot is offline
post #11 of 90 Old 10-19-2012, 10:00 PM
MD97ZJ
Alpine Type R components
Infinity Refrence rear doors
Polk MM 10"sub (hits Suprisingly hard)
Alpine head unit
Built for sound quality not overwhelming Bass
MD97ZJ is offline
post #12 of 90 Old 10-20-2012, 04:27 AM
ejschultz
ejschultz's Avatar
I'm running an Alpine CDA-9855 (active), an MRV-F345, MRV-M605, Pioneer TS-D1720C components, and an Alpine SWX-1043D in a small sealed enclosure. That's gotta be one of the loudest single 10 setups I've heard, especially considering I'm only giving it 600 RMS and it's in a sealed enclosure. I built the system for sound quality though. It's definitely clean. If you want to see more of my setup, click on my build log in my sig. The first handful of pages in there deal with only the system. Then it goes into the suspension and bounces back and forth to and from the system. It's changed quite a bit in the last 2.5 years.
ejschultz is offline
post #13 of 90 Old 10-20-2012, 08:06 AM
SPAWNofTW1ST3D
I have a custom one off tuned box made just for my Kenwood KFC-W3013PS being powered by a Hifonics 2500 watt class D amp with Kenwood KFC-P709PS in my doors and 4 Kenwood KFC-ST01 tweeters in the dash, this system will make your ears bleed!
SPAWNofTW1ST3D is offline
post #14 of 90 Old 10-21-2012, 07:08 PM
Azalin_00
I see a lot if claims, and no pictures to support them.lol
Baller on a Budget
My Money
My Ears
My Jeep
post #15 of 90 Old 10-21-2012, 07:15 PM
ejschultz
ejschultz's Avatar
My claim is in my build thread which is in my sig.
