Sound System - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Sound System
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenRight Offroad at CCOR! 706-207-4140Rough Country Lift Kits and Parts!
Unread 06-22-2005, 07:44 AM   #1
RAZZMANIAC
Sound System
The speakers in my 97 GC are kinda shot. I went to a shop to find out about replacing them, they told me cause its an INFINITY AMPLIFIED SYSTEM (stock) that they would need to be rewired anyway. So far 2 people told me this. Is this true if the dealership was to replace them with stock speakers??
1997 Grand Cherokee 5.2L Tsi
RAZZMANIAC is offline   Reply With Quote
Unread 06-22-2005, 07:57 AM   #2
Phil Gerard
Former Mod
Phil Gerard's Avatar
That's not true at all, unless they mean the crossover wiring between the front door speakers and the dash tweeters.
The reality is you can replace any speaker and use the stock amp just get speakers that have high sensitivity (don't require a lot of power) because the Infinity amp is not exactly a boomer!
Phil
'95 ZJ Ltd. White 4.0L
TW DC DS; ARB Bull Bar, F&R Air Lockers; Superior Axles; Warn Winch; 4.56 gears; ACOS, Addco F&R Sw Bar, JKS Discos, Rr Track Bar & Nerfs, 249>242 Swap, Stillen rotors+Kolak pads, 3 pc. Armor, RE 4.5 Kit + 2.5"BB, Adj. UCAs&LCAs, OME SS, Bilstein 5150s, 15x8 AR Diamond Backs, 33 Truxus MTs, K&N FIPK, RE 62mm TB, Perf. Distr. 4.0L Kit, Exhaust: 2.5" Kolak exhaust FM 70: Optima Yellow, Mean Grn Alt., PIAA 520s, 540s, Kevins Rack, & TB Conversion
Phil Gerard is offline   Reply With Quote
Unread 06-22-2005, 08:03 AM   #3
PlatinumZJ
Senior Moment Member
PlatinumZJ's Avatar
Razz, try crutchfield, they can give you a name, model No, etc. of the speakers you need that will work with your infinity gold system. you can buy from them or try to find a better price for the items you find there. good luck
http://www.crutchfield.com/
Doug
When all is said and done, more is said than done.
Platinum '97 ZJ LTD, I6 (see profile) Paid for!
Links: Kevin (AKA KOR) for ZJ & WJ stuff,
Kolak for performance stuff. I6 performance info at Dino's jeep 4.0 performance site
Other stuff: Kevin's Roof Rack. KOR sliders, Bored 62mm TB, Blaupunkt Bermuda w/ ipod, Brembo Slotted rotors,
OME steering stabilizer, H4 headlight upgrade...
PlatinumZJ is offline   Reply With Quote
Unread 06-22-2005, 08:15 AM   #4
RAZZMANIAC
Thanks guys
