sort of newb Q (tire wear) - JeepForum.com
post #1 of 3 Old 07-28-2011, 11:28 PM Thread Starter
sandman
So... long ago I was told that my front tires will wear faster than my rears but that was back when i was running a 249 now that i have a 231 is this still the case? It is a DD that only sees 4wd once a month or so. most of my miles are street and in RWD.
1993 Jeep ZJ. 4.0
sandman is offline
post #2 of 3 Old 07-28-2011, 11:41 PM
my2monkeys
1989 XJ Cherokee
They should wear the same as long as you rotate them.
Was is hard to swap the 249 to a 231?
My wifes ZJ has a 249 and I just swapped my 89 xj's 242 out w/a used 242, so I'm thinking of rebuilding it and putting it in the ZJ.
wifes 95zj 4.0 42re np249 201,000mi
mine 89 xj 4.0 aw4 np242 445,000mi
nephews 98 zj laredo 4.0 2WD 213690mi
my2monkeys is offline
post #3 of 3 Old 07-29-2011, 01:32 AM
jnicewan
Tire wear usually depends on the vehicle and driver habits. If you do a lot of city driving (turning) you will probably see more frt tire wear. If you have a heavy foot (not that a 4.0 is a tire shredder) or rear locker you will probably see more rear tire wear.
A proper alignment will also help tire wear on the front.
jnicewan is offline
Tire wear... MrWiggles ZJ Grand Cherokee Forum 16 11-04-2009 01:14 AM
tire wear footinmouth47 ZJ Grand Cherokee Forum 1 10-30-2009 07:43 AM
Really Bad tire wear, tire angle? 12xracer ZJ Grand Cherokee Forum 6 06-25-2008 06:43 AM
Tire Wear shashank ZJ Grand Cherokee Forum 6 10-19-2006 06:29 PM
Tire Wear boilingpoint ZJ Grand Cherokee Forum 2 05-18-2004 01:23 AM
