Sorry another general set of questions - JeepForum.com
post #1 of 5 Old 05-01-2004, 09:31 PM Thread Starter
cfkingfish
cfkingfish's Avatar
I dont have the ability to check out what the specs are on my sister's 94 ZJ limited. It has the 5.2 V8 like I said, but what transmission/T-case/front and rear axle setup do I have? The 4wd shifter says 4 full time, neutral, and 4 Lo. Is this quadratrac? And who makes this T-case and what is it called? Sorry I am a little confused.
-Christian
Christian
89 XJ 4.0 AW4
K&N 6x9 cone filter setup
Converted to TJ axles - 5-297 U-joints
Optima Red Top
Custom exhaust
www.ishopfaulkner.com
cfkingfish is offline
post #2 of 5 Old 05-02-2004, 12:52 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Hey,
don't be confused. You have the quadratrac. You most 99 percent have the dana 35 rear axle and dana 30 front.
Check out the specs pages on www.nagca.com under tech links.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #3 of 5 Old 05-02-2004, 06:17 AM
Meerkat
-Christian
Here is a fun little site, where you can decode your VIN , then, once you've done that, you can send an email with your VIN to these guys with your VIN requesting a build sheet.
HTH
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #4 of 5 Old 05-02-2004, 06:52 AM
djorkboy
djorkboy's Avatar
HTH
cool site, thanks. I discovered that my Grand Cherokee was built in Austria
djorkboy is offline
post #5 of 5 Old 05-02-2004, 09:28 PM Thread Starter
cfkingfish
cfkingfish's Avatar
Thanks for all the info, its good to hear that the axles are just like the ones on my 89 XJ.
-Christian
Christian
89 XJ 4.0 AW4
Optima Red Top
Custom exhaust
hello, general questions... robertg ZJ Grand Cherokee Forum 12 03-24-2008 09:56 PM
General Questions bbhockey19 ZJ Grand Cherokee Forum 3 01-02-2008 09:15 AM
ZJ - WJ General questions K9-Handler ZJ Grand Cherokee Forum 6 10-18-2007 11:57 AM
5.2L v8 General Questions Deblanc ZJ Grand Cherokee Forum 23 08-09-2007 12:57 AM
General GC questions sknot1454 ZJ Grand Cherokee Forum 6 02-18-2003 12:24 AM
