Some transmission problems and then some - Page 2 - JeepForum.com
post #16 of 17 Old 03-31-2004, 11:45 AM Thread Starter
BOOM
OK guys, Sorry i took so long to respond. I went ahead and worked on my car this weekend. I changed the fluid and filter. I also checked my tps and it seems fine. I adjusted the bands ( the one by the filter ) and i tried to adjust the bands on the outside one. The socket I need to adjust the bands are square. I used a 1/4 inch hex socket on the inside one and it seemed to work fine to torque with, but the outer one I need to find a 3/8 square socket or something comparable. I don't know what they're called and I checked all over town for one yesterday. I tried to find a 8 point socket, but only found 12 point and they would not fit. Does anyone know what this particular socket is called or where i could find one, or somehow of doing the torque without it ? ? ? Other than that everything seems to be running smoother and I haven't been experiencing slippage I'm still having a slight issue with my idle being a bit low when i pull up to a stop. It will sometimes jerk a little bit like a gas cutoff or something. And I'm still having some vibrations when accelerating and when cruising along in overdrive. Well that's all for now. Hope you guys can help. Boy am I a project
Thanks
BOOM
94' Grand Cherokee Laredo
i6 4.0 Liter 4 X 2
BOOM is offline
post #17 of 17 Old 04-02-2004, 10:57 PM Thread Starter
BOOM
I guess my next option is to go ahead and check out my bearings. I hate having to go through this again. I went to change em out on my first engine and some *** left my engine open for six months letting it rust. But if i gotta i will. So we'll see how this weekend goes with that
BOOM
i6 4.0 Liter 4 X 2
BOOM is offline
transmission problems dex1 ZJ Grand Cherokee Forum 1 11-29-2008 07:47 PM
Transmission problems. HELP! jmack549 WK Grand Cherokee & XK Commander Forum 9 10-30-2008 11:01 PM
'98 transmission problems gbt102 ZJ Grand Cherokee Forum 4 08-24-2006 08:11 PM
Transmission problems (TCU or TCM) remicman WJ Grand Cherokee Forum 4 06-03-2004 08:31 PM
Transmission Problems JeepGuyRyan ZJ Grand Cherokee Forum 5 08-09-2002 07:45 PM
