Is some trackbar movement normal? - JeepForum.com
post #1 of 26 Old 09-24-2017, 06:14 PM Thread Starter
Mopar4U
96 zj 5.2 limited
Trying to track down a mild thud noise when hitting rough terrain (offroad trails, my yard, pothole).
New moog trackbar
New moog sway bar links and inner bushings
New moog tie rod ends
New spicer upper and lower ball joints
It was mentioned that the moog trackbar bushing could be too soft and hitting the axle mount, here is a video. This look bad?
https://youtu.be/pJTs5xUOyA8
Mopar4U is offline
post #2 of 26 Old 09-24-2017, 06:55 PM
GOLDWING
You need to replace the bushing with a Moog poly 3 piece axle end bushing. Mine did the same thing. They are about $20 at O'Reillys.
GW
2 '98 4.0 ZJs
Hers is stock, mine, OME shocks, BB, Aussie, 2x6 sliders, 31s, etc.
GOLDWING is offline
post #3 of 26 Old 09-24-2017, 06:56 PM
GOLDWING
Put in a Moog 3 piece axle end poly bushing. $20 at O'Reillys.
GW
2 '98 4.0 ZJs
GOLDWING is offline
post #4 of 26 Old 09-24-2017, 07:05 PM
1996jz
I'm having the same noise in my 4.0. Firestone told me I needed new CAs and quoted me $850...lmao. could CAs cause this noise?
Sent from my Nexus 6 using Tapatalk
1996jz is offline
post #5 of 26 Old 09-24-2017, 07:13 PM Thread Starter
Mopar4U
i can see how the 3 piece would tighten up my steering but i dont see how this movement causes a thud/clunk??
i havent done control arms either but not sure how to tell if they are bad. the upper bushing that needs to be pressed out and in the frame looks like a nightmare
Mopar4U is offline
post #6 of 26 Old 09-24-2017, 07:21 PM
1996jz
Idk either but for sure won't take anything to Firestone again. Jeep still doesn't roll straight after two alignments.
1996jz is offline
post #7 of 26 Old 09-24-2017, 07:28 PM
azzkicker
2007 WK
You probably have already, but you might check your skid plates to see if the bolts are tight. I've had clunking from that a number of times.
Are your new bushings poly now instead of rubber? In my opinion, poly clunks compared to rubber, but it lasts longer and seems cooler.
Anything can do that, loose wheel bearings, loose anything. I'd start by grabbing the top of the tire and shaking it in and out. See if you can make anything clunk. Then, get a strong friend and have them muscle the wheel back and forth while you lay under it (engine off, thus the strong friend).
Then, if still no clues, take a good look around at clearances, then jack up the rig and put jackstands under the frame, so the suspension hangs, and look again. Use a strong light. You can go as far as to leave one wheel down at a time, and do the same check.
07 WK 5.7 QD2, 4" lift, 33X10" tires, M8000s
ARB twin air,Dual AGM group 49, sliders and skids
azzkicker is online now
post #8 of 26 Old 09-24-2017, 07:38 PM Thread Starter
Mopar4U
no skid plates on my rig
all my bushings are rubber i believe.
seems like ive been under my jeep more than driving it looking for this noise....,
Mopar4U is offline
post #9 of 26 Old 09-24-2017, 07:57 PM
kg6mov
Hears the voices
kg6mov's Avatar
Any play in the trackbar is a bad thing, that's much more than I would be comfortable with.
Have you loosened and retorqued all the bolts for the track bar bracket?
kg6mov is offline
post #10 of 26 Old 09-24-2017, 09:59 PM
Timo_90xj
Timo_90xj's Avatar
Yeap, that's too much movement on a trackbar. Trackbar is about the only place where I can recommend poly bushings, unless you can find a rubber bushing that is hard enough. The one in your new Moog track bar certainly is a bit too soft.
***Under construction***
Timo_90xj is offline
post #11 of 26 Old 09-25-2017, 06:10 AM Thread Starter
Mopar4U
Would this movement create any kind of noise when driving on rough terrain?
Mopar4U is offline
post #12 of 26 Old 09-25-2017, 12:13 PM
kg6mov
Hears the voices
kg6mov's Avatar
Yes, as the suspension is cycling the trackbar will probably clunk in the bracket.
kg6mov is offline
post #13 of 26 Old 09-25-2017, 05:56 PM Thread Starter
Mopar4U
do the 3 piece moog poly bushings need to be greased?
Mopar4U is offline
post #14 of 26 Old 09-25-2017, 10:56 PM
GOLDWING
Nope.
GW
2 '98 4.0 ZJs
GOLDWING is offline
post #15 of 26 Old 09-25-2017, 11:29 PM
Timo_90xj
Timo_90xj's Avatar
I would use high quality grease on them, both to prevent premature wear and to keep them from squeaking.
