Some questions for you ZJ guys - JeepForum.com
post #1 of 13 Old 07-27-2009, 06:45 PM Thread Starter
Tatersaladx
My buddys got a zj, and is look to lift it so we were thinking of putting my old xj 3" coils and HP axle if its the same gears. and the front to back coil swap. To fit 31s. Now the reason for the HP D30 is that his lp D30 completely shat the bed it makes clunking sounds from the diff and he lost 4wd(Quadratrac) but somehow has park. But i was wondering what possible geats a 98 4.0 ZJ with Quadratrac would have. and how to tell.
Tatersaladx is offline
post #2 of 13 Old 07-27-2009, 06:51 PM
squashman702
1994 ZJ
Get a build sheet from Chrysler by using the VIN. If the ZJ has a factory tow package (it will have a hitch with wiring and a tranny cooler) then it likely has the 3.73's. The only other ratio available was 3.55, similar to most XJ's. It still has park because park does not rely on the front axle in later quadratrac ZJ's.
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline
post #3 of 13 Old 07-27-2009, 06:55 PM Thread Starter
Tatersaladx
well when its jacked up and in park the right front wheel doesnt turn so it is in the front axle. Next time i look at it ill look for the tranny cooler cause it does have a receiver and hitch.
post #4 of 13 Old 07-27-2009, 07:05 PM
Greeeeenberg
98 4.0L should have 3.55 and dana 30 front and dana 35 rear. Crawl underneath there and look at the diffs. If the rear diff is rubber plug its a 44a and it has 3.73s. If its a metal plug like the front then 35 it will have 3.55s.
Like he said the later model 249s could park without front driveshaft/axle working properly. Open the diff and see whats going on in there. Also might be a bad CV or u-Joint in the front.
97 ZJ Orvis 5.2 108K.
Member #1
Greeeeenberg is offline
post #5 of 13 Old 07-27-2009, 07:19 PM Thread Starter
Tatersaladx
Well i think my XJ axle is 3.55 incase it is the diff might as well upgrade to HP, im gonna jack it up and see if its 3 1/2 turns. So should he remove the front driveshaft im not rly knowledgable in the 249. I do kno tht hes gonna eventually swap that with a 232 when he replaces his tranny. Also what rtv and gear oil should i buy when i rip the diff cover off
post #6 of 13 Old 07-27-2009, 08:20 PM
WhiteOut
WhiteOut's Avatar
Putting the XJ coils up front will net less than 3" of lift while the front ZJ springs in the back will get about 3.5
WhiteOut is offline
post #7 of 13 Old 07-27-2009, 08:52 PM
SnowLeopard
Not meaning to hijack a thread here, but I have a question about this. My build sheet says I have the 35C, and I've never questioned that. But I tried to rub off the grease and dirt a short while back to see if I could find anything written on it, and all I found was DANA etched in the metal, and then a rubber plug with DANA on it as well. It's a rubber plug, and by what you're saying the rubber plugs were only in the 44's? I really can't imagine I lucked out, and the build sheet is just wrong so that I have a 44 with my I6 and 3.73 gearing. It's a bit difficult for some of us to identify our axles is all. I'm not the most mechanically inclined. LOL
SnowLeopard is offline
post #8 of 13 Old 07-27-2009, 09:31 PM
elmer_fud
the 35 also has a rubber plug in ZJ's
Brian
95 ZJ, 5.2 V8,160,000 miles
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline
post #9 of 13 Old 07-27-2009, 09:32 PM
elmer_fud
Check the tags on your diffs to figure out what gearing you have.
Brian
post #10 of 13 Old 07-27-2009, 10:44 PM
befumo
x2.
4.0 w/ Dana 30/35 with 3.73 gears. So check your tags!
'89 YJ Wrangler - Sold
'95 ZJ Orvis Edition
'89 YJ Islander
befumo is offline
post #11 of 13 Old 07-27-2009, 10:52 PM
SnowLeopard
The build sheet says 3.73 gearing with the tow-prep package. I have the auxiliary cooling but not the prep-wiring harness for the trailer hookup in the back. Strange, eh? I will have to look more closely at the axle when there's daylight once more. The build sheet says 35c, and that's likely what it is. It's just that Green said that about the rubber plug, and I remembered seeing it on the diff cover.
post #12 of 13 Old 07-28-2009, 11:30 PM
rooster51
you have the dana 35c. the "C" means custom, meaning it was assembled elseware. cant remember where.
rooster51 is offline
post #13 of 13 Old 07-28-2009, 11:42 PM
Virmagicus
Virmagicus's Avatar
Yes , some people think the c stands for c-clip .They are custom because they are shipped incomplete from the Dana factory to Chysler and Chrysler completes the build.
Jeff
Virmagicus is offline
A Few Questions For You 5.7l Hemi guys jeepin08123 WK Grand Cherokee & XK Commander Forum 40 06-16-2014 01:57 PM
Any Bay Area, Ca Guys On Here? Also Taking Hemi To The Drags, Questions. TatorTodd WK Grand Cherokee & XK Commander Forum 1 01-10-2010 10:17 PM
Tranny, Filter, and service questions? 42RE GUYS IN HERE Dopalmer ZJ Grand Cherokee Forum 5 05-13-2009 04:13 PM
Help me with New buy Questions.. please guys, a list Jetjock16 ZJ Grand Cherokee Forum 13 09-23-2005 10:32 PM
Questions for the smart guys grandman97 ZJ Grand Cherokee Forum 8 02-16-2005 11:28 PM
