Some days it'll start instantly, other days it'll take a couple seconds - JeepForum.com
post #1 of 12 Old 05-03-2013, 06:17 AM Thread Starter
herculeesjr
The title describes it pretty well. I rebuilt the throttle body when I bought this Jeep, and a couple months ago I cleaned it to see if it would help, but no luck and it wasn't even very dirty. I have no pending or confirmed codes and no vacuum leaks and it runs great, it just bugs me how I literally just tap the start and it fires up, then other times I have to hold it on the start for I'd say an average of 2-3seconds, sometimes more. Engine temp doesn't appear to matter either.
I know I'm being really picky but I'm just wondering if anyone had any suggestions or if over all this is just normal and you can't change it? I'm OCD and I aim to have everything perfect. :P
herculeesjr is offline
post #2 of 12 Old 05-03-2013, 06:20 AM
wtb300
1994 ZJ
I'm thinking coil mine was the same way till it went out on the highway lol
I should add that I'm a learn as I go mechanic so to speak so I could be way off but the new coil I bought solved that for me
wtb300 is offline
post #3 of 12 Old 05-03-2013, 06:32 AM Thread Starter
herculeesjr
Hmm I forgot about that. I found a crack in my coil lil over half a year ago and replaced it when trying to diagnose the infamous ECM stall issue I had yet to hear about (fixed by bending the pins that connect the two halves of the ECM together to connect better) but I got a Duralast coil or some AutoZone brand like that and every rare once and awhile I'll find a pending code saying something about the coil. I keep hearing about ignition upgrades for this engine so maybe I'll see what this "upgrade" is and do it.
post #4 of 12 Old 05-03-2013, 07:39 AM
Technohead
My first guess is fuel pump.
-Eric
Technohead is offline
post #5 of 12 Old 05-03-2013, 07:57 AM Thread Starter
herculeesjr
Though it's not hooked up 24/7 to a pressure gauge I did have a pressure gauge on it for a day and it never went under, if I remember correctly, 42psi at the fuel rail.
post #6 of 12 Old 05-03-2013, 08:49 AM
Moparmissus
1994 ZJ
Are the days it "takes a little longer" wet days? Old Mopars had an issue with wet weather/high humidity starts. I used to carry a can of WD-40 in the glovebox of my '67 Valiant!
Moparmissus is offline
post #7 of 12 Old 05-03-2013, 11:32 AM Thread Starter
herculeesjr
Nope, it's completely independent of weather, I was suspecting as it warmed up and winter went away it would be happy again but zero difference from a 30F snow/rain day and 75F day.
post #8 of 12 Old 05-03-2013, 01:45 PM
tucsonzj
Some days mine cranks a little longer then others, but if I stick the key in the ignition to the "on" position, just before the start, let it sit for about 5 seconds then hit it to start it fires right up every time.
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #9 of 12 Old 05-03-2013, 02:01 PM Thread Starter
herculeesjr
I've tried that too with no luck sadly. Most of the time I don't even stop at Run I'll put the key in and straight to Start. But even after counting to five every time I start it for a few days it made no difference.
I just can't even find anything to point me in a direction. Rain or sun, hot or cold, waiting or instantly starting, it four out of ten times will take a couple seconds on the starter. Some times when it's on the starter you can feel the engine stumbling for a split second then it kicks and it's running, other times it's like the injectors are off while it's starting for a second and then they're turned on and it's running.
post #10 of 12 Old 05-03-2013, 02:08 PM
capcyclone
capcyclone's Avatar
I'll have to try this technique, because I have the same odd starting issue. "Issue" is a strong word because its more of an annoyance than a problem. It's so minor I'm fact, that I'm hesitant to mess with anything simply because its acted like this for years and its been no better or worse. But trying a different start "routine"at do the trick.
"The Jeep is America's only real sports car" - Enzo Ferrari
'98 Jeep GC 5.2L "ZJ" - Sold
'02 Jeep GC 4.7L HO "WJ" - Daily driver
capcyclone is offline
post #11 of 12 Old 05-03-2013, 02:23 PM
tucsonzj
my thought process, crank shaft position sensor. I replaced mine with a non mopar(mistake) but it still works, but ever since then is when I have this weird start.
tucsonzj is offline
post #12 of 12 Old 05-03-2013, 02:25 PM
pauper
Ordered a good quality fuel pump assembly from Kolak..
I used to play the "cycle the key on and off game"....
no more issues and I honestly feel that 5.9 pulls harder thru 2nd gear.
my 2 cents...
pauper is offline
