Socket stuck on axle nut - JeepForum.com
post #1 of 14 Old 03-03-2013, 12:24 PM Thread Starter
Drewbe
1994 ZJ
Ok I have came across this problem before but not this bad. I'm replacing my drivers front axle shaft on my 94 zj. My buddy brought a 35mm socket not the 36 that we needed before I knew it he had smacked it on to the shaft nut and needless to say it's stuck and the nut won't come loose. We broke 2 Marco breaker bars trying to break it loose along with using pb and mapp gas torch. Now I just want to get the socket off! Anyone have any ideas? I don't have any air tools and only a tiny bs compressor.
Drewbe is offline
post #2 of 14 Old 03-03-2013, 12:27 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Break free, WD 40
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #3 of 14 Old 03-03-2013, 12:28 PM
dnuccio
Smack it off with a hammer, shouldn't be too hard
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #4 of 14 Old 03-03-2013, 12:30 PM
970001zj
x2
97 zj orvis/04 wj ltd/02 lancer oz rally/85 rx7 gs
970001zj is offline
post #5 of 14 Old 03-03-2013, 12:33 PM
MustangFX93
I think what he's saying is that the nut, after having removed it from the axle, is stuck inside of the socket. So, really, he needs something to pry it outta there with.
MustangFX93 is offline
post #6 of 14 Old 03-03-2013, 12:38 PM
Snowfan2
Tap it with a hammer-gently-from the side, all the way around. It wants off of there too, be patient. If its off with the nut inside, put the socket in a vise and go through the square hole with a punch. All the way around is the best way. Little here, little there.
Snowfan2 is offline
post #7 of 14 Old 03-03-2013, 12:38 PM Thread Starter
Drewbe
1994 ZJ
Thank you for the fast responses. I've been smacking it with a baby slug for a hour I even slammed a nut through the hole and screwed a bolt in it and have been hitting a plate I attached to the bolt. I think I'm gonna have to put everything back on over the socket and drive it to the shop tomorrow so we can cut the socket off. I'm at a loss lol. I still can't believe he smacked a 35mm on a 36mm nut but stuff happens.
Drewbe is offline
post #8 of 14 Old 03-03-2013, 12:38 PM
yjtyler
I just did this exact thing with the pinion nut!! Simple answer, u won't get it out without either breaking the socket or cutting the nut out. I'm glad I had snapon because they replaced the socket that I beat the sh't out of. And of course I had to get a new nut
http://www.jeepforum.com/forum/f12/350-swap-time-near-1406658
yjtyler is offline
post #9 of 14 Old 03-03-2013, 12:59 PM
Uniblurb
Uniblurb's Avatar
Just throw it in the trash and get a new nut while using the correct sized socket. Neither one is going to be worth a crap with the points rounded off and you'll have more $ involved in a shop cutting the socket off than a new nut is going to cost.
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 96 4.0 XJ (son's)
Uniblurb is online now
post #10 of 14 Old 03-03-2013, 01:04 PM Thread Starter
Drewbe
1994 ZJ
Yeah I don't care about the nut except it's still on the shaft so I have a socket stuck on nut that's stuck on the shaft that's still on my jeep. I'm just gonna take it in and have them cut both off.
Drewbe is offline
post #11 of 14 Old 03-03-2013, 01:08 PM
dnuccio
BFH is your answer. if you dont have one, get one. theyre cheap and will help with other things later on down the road
R.I.P. Ratmonkey
dnuccio is offline
post #12 of 14 Old 03-03-2013, 01:18 PM Thread Starter
Drewbe
1994 ZJ
Holy sh*t BFH worked! 10 pounder and some good swings from every angle she popped off. Thank you all for your input.
Drewbe is offline
post #13 of 14 Old 03-03-2013, 05:01 PM
SAR-Swimmer
A BFH is one of the best "fine tuning tools", I've come across.
SAR-Swimmer is online now
post #14 of 14 Old 03-03-2013, 05:01 PM
dnuccio
gotta have the precision tool for the job
R.I.P. Ratmonkey
dnuccio is offline
cj , tj , wj , xj
