So who's towing out there? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > So who's towing out there?
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFS: Wranger BRIGHT License Plate LED! Just $3! Great valueSteering Stabilizer Brackets...
Unread 04-13-2011, 11:05 PM   #1
porrsher
1994 ZJ
Hey guys,
Small dilemma here, I just bought a small size (18ft) Hybrid Travel Trailer for camping trips. When I hooked it up to the ZJ I quickly discovered that it almost popped a wheelie. So long story short, I am now aware that I'll be needing a Weight Distribution Hitch. The trailer weights in at 3100 empty, I would guestimate it at 3600 +/- with all gear. Tongue seems to be about 400.
I'd like to get some feed back from anyone towing similar loads with their ZJ. I am wondering if the 5.2L would be fine and I'm concerned about the short wheel base.
Feed back really appreciated. I really do not want to be unsafe while towing.
1994 Hunter Green ZJ 5.2L Quadratrac
228k Miles, 2" BB.
2002 Slate Grey Grand Cherokee Overland
161k Bone Stock
2008 Black JK Sahara Unlimited (Love it!)
porrsher is offline   Reply With Quote Quick reply to this message
Unread 04-13-2011, 11:40 PM   #2
BrandonLong
How are the springs?
BrandonLong is offline   Reply With Quote Quick reply to this message
Unread 04-13-2011, 11:55 PM   #3
biebs53
Is it all stock suspension? I only flat tow the TJ or baja bug with my ZJ. Use the f150 with air bag suspension to tow the boat.
[CENTER][FONT="Franklin Gothic Medium"]1998 Jeep Grand Cherokee 5.9 Limited
Build thread: [url]http://www.jeepforum.com/forum/f197/project-raven-biebs53-build-thread-1215245/[/FONT][/url][/CENTER]
biebs53 is offline   Reply With Quote Quick reply to this message
Unread 04-14-2011, 01:02 AM   #4
HeavyArms
the previous owner of my zj towed a camper about the same size. not sure about the weight but i know the lenght was close. he told me it did okay.
well when i got the jeep it had a rebuilt trans, whole new cooling system, and E load range tires. didnt think much of it at the time.
turns out that the "frame" was cracked on each side right after the reese hitch. twards the front of the jeep right after the shock mounts. so be carefull towing a heavy load and check for cracks afterwords.
Wiggle wiggle wiggle
HeavyArms is offline   Reply With Quote Quick reply to this message
Unread 04-14-2011, 01:07 AM   #5
RobsCrawlin7
no balls
RobsCrawlin7's Avatar
you should be fine with the weight distro hitch. I LOVE having my 350, i never worry about towing.
'01 TJ 4.7/NV3550, 2" lift, 35's, locked.
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
SSG David Mejias, SSG Eric Vick, SGT William Bowling, SGT Robert McDowell
1 April 2007
Rest In Peace Brothers
RobsCrawlin7 is offline   Reply With Quote Quick reply to this message
Unread 04-14-2011, 01:08 AM   #6
Technohead
Old School
Technohead's Avatar
You will be fine. Weight distributing hitch will make a WORLD of difference. If you tow regularly then change tranny fluid alot more often.
Technohead is offline   Reply With Quote Quick reply to this message
Unread 04-14-2011, 01:10 AM   #7
ZJ5point2GCL
should be fine with with the weight distributing hitch, ive towed allot of weight, when the trucks are in the shop or just to see what it'll do, i mean they are not the best tow rig, but still pretty capable.
98 Deep Slate Niner- 6''s on 35's ---11 F150 Platinum Pearl White- Modded Tiny V6 with Two Turbos. ---93 Black 5.2 limited- Slowly dying in my Parents Driveway
ZJ5point2GCL is offline   Reply With Quote Quick reply to this message
Unread 04-14-2011, 01:11 AM   #8
NW-XJ
You will have plenty of power, the front end will be a little bit lighter, But your brakes will suck. Electric brakes are a must (witch should be standard on any newer 18ft trailer) your tow rating should be 6500lbs, so a weight Dist hitch will make the job a breeze. Just becareful of that "breeze" on the highway!
5.9 ZJ
add ons: Go fast stuff, Stop fast stuff, offroad stuff, and bright lights.
NW-XJ is offline   Reply With Quote Quick reply to this message
Unread 04-14-2011, 06:53 AM   #9
porrsher
1994 ZJ
Thanks for the replies guys. The springs i feel are a littlr weak. After all it is a 17 yr old zj. it's bone stock. Heavy arms, with the zj's unibody, when you say cracked frame was that literally a crack under the Jeep? And yes NW your right about the brakes, luckily the camper has surge brakes.
228k Miles, 2" BB.
161k Bone Stock
Unread 04-14-2011, 08:48 AM   #10
mrfister11
my 95 zj with 5.5 inches of lift i hauled a 16ft flatbed trailer that weighed 2500lbs and put a huge tractor with a brush hog that hung off the end about 6-7ft.. almost too much for the trailer.. and the jeep drove fine. i drove down highway at 65 and alot of it was twisty hilly roads. .that jeep had 320k miles, 5.2l and never had the tranny out.. it bottomed out the rear springs which made for a nicer ride honestly.. brakes were ok just be prepared to stop with the weight i had.. your weight should be fine.. also my 96 5.2 that was bone stock i pulled about 5k and it also bottomed springs out and it drove really nice.. had my 6ft tall toolbox full of tools on the front of a flatbed trailer.. had no problem with it.. both these jeeps came with factory tow package.. make sure your trans shifts fine under that kind of load.. if it doesnt then dont pull anything.. ha
mrfister11 is offline   Reply With Quote Quick reply to this message
Unread 04-14-2011, 09:34 AM   #11
Technohead
Old School
Technohead's Avatar
note that surge brakes are not compatible with most weight distributing systems. I think reese might make one that is.
Unread 04-14-2011, 12:52 PM   #12
NW-XJ
My flatbed trailer has surge brakes, keep in mind that style of trailer brakes can be extremely inadequate in alot of situations.. I highly suggest upgrading to E-brake axles.. If its a tandem axle, any trailer shop should be able to set you up.
5.9 ZJ
Unread 04-14-2011, 02:03 PM   #13
KingtheZJ
i towed a suabru on a uhaul flat bed once with mine. the car was 3200 and the trailer was 1900. it had surge brakes and i barely knew it was there. it definitely weighed the back down thought. i would look at the towing air bags that go inside the coils if i was going to do it a lot.
'98 ZJ on 37s and tons
'97 Cummins 2500
KingtheZJ is offline   Reply With Quote Quick reply to this message
