so whats needed to lift zj 3.5 inches - JeepForum.com
post #1 of 9 Old 03-20-2014, 07:21 PM Thread Starter
100branson
Im doing with out trying to pour tons money then whats needed but I want it to to keep it descent ride n none of the huge crappy spacers. Will I need longer brake lines extended sway bar links and so on?
I know new extended struts cause current ones are shot
100branson is offline
post #2 of 9 Old 03-20-2014, 07:40 PM
riot1987
Search the forum a bit and youll find all you need to know.
Build thread^^
riot1987 is offline
post #3 of 9 Old 03-20-2014, 08:40 PM
Vertical4
2014 JK Wrangler
If you are looking for a decent but not too pricey lift kit, I suggest you check out Rubicon Express's 3.5'' Super-Flex short arm lift kit. It comes with everything you need for the 3.5'' lift and it is a very flexible lift. If you have any questions, feel free to ask!
-Jim at Vertical4
GO WHERE OTHERS FEAR
Vertical4 is offline
post #4 of 9 Old 03-21-2014, 07:25 AM Thread Starter
100branson
Found this off a site may do this any opinions?
using ford thunderbird front springs to lift the front of my ZJ around 3.5"
*here isI found out about
*and here is some info I found on the springs:
*Front coil springs from a 3.8 V6 equipped Ford Thunderbird/Cougar offer 3-4in of lift and the softer ones noted below ride and flex like stock XJ coils.
*83-88 TBird, Cougar = more lift
89-97 TBird, Cougar = less lift
post #5 of 9 Old 03-21-2014, 09:33 AM
Myusername1674
Or just spend $120 or so and get real lift coils... hahah
95 FiveTwo ZJ, DD, Lifted, Locked on 35s,
(in progress)
Myusername1674 is offline
post #6 of 9 Old 03-21-2014, 09:42 AM Thread Starter
100branson
Yeah sounds easier haha
post #7 of 9 Old 03-21-2014, 10:01 AM
Myusername1674
It is man, just buy some front coils, put your oem fronts in the rear, buy front and rear track bars and maybe a few other things as needed, then call it good
(in progress)
post #8 of 9 Old 03-21-2014, 10:03 AM
cekmgreen
plus old thunder turd coils are going to be worn out and saggy, i got my 5.5 coils from iron rock i like them flex almost to much
cekmgreen is offline
post #9 of 9 Old 03-21-2014, 11:12 AM
WhiteOut
WhiteOut's Avatar
-Jim at Vertical4
He's going to need about $400-$500 more in parts to run that kit.
WhiteOut is offline
