So what do you think??? - Page 2 - JeepForum.com
post #16 of 27 Old 06-04-2010, 12:04 AM
WJ Freak
Originally Posted by BreadsWJ View Post
Well, I installed the BPE's (yes the JKS ones) and the harder clunking disappeared, YAY!!!!!!!
As for the creaking, I've minimized it by greasing up the heck out of almost every bushing and moving part I could find under there! Creaking is almost gone, just very faint. I still think I have to remove the trackbar completely and lube up the bushings with some Red N' Tacky to see if that cures it completely.
As for the whining, I haven't had the time to pinpoint it, but I have to replace my condenser next week so I'll see if it's the steering pump, or drive shaft or something??
Meanwhile, I've also got some OEM roof cross bars from Ebay for $40, they were in mint condition and looking at getting some lights for the Safari Bar.
Still gotta get my hitch and a few other goodies.
If anyone has instructions for installing (the wiring part of it) the 2 lights on the Safari Bar, please post a link. I couldn't find any definitive "best way" to fish the wiring through to the inside dash.
What was said in other threads is very true....I have the 2" BB, and I wish I just waited and got the 4"!!!!!!!
Thanks to all, will keep this thread updated with pics and progress!!
Cheers from Canada
I'll try to take some pics of the threading of my KC wires. I ran them right up into my bumper, along the left inside of the grille, to the battery, then back to the firewall, along and below the rubber hood seal in front of the dash/windshield, then I actually ran it through the same opening as the rest of the wire cluster for the steering column and mounted the switch in that little rubber area to the lower left of the steering column that flexes. The whole thing took about an hour.
!!!!!!!FOR SALE!!!!!!!! '02 WJ Graphite Limited 4.7 with all options; IRO 5.5" coils; JKS U/L CAs; RK Adj. TB; MX-6; JKS Discos; JKS BPEs; Hard-KOR SS; KOR Endlinks; Rear Addco; IRO A-arm spacer; BS Ext.; Ext. SRs; 255/75-R17 BFG M/Ts; 17" Chrome Torque Wheels; SpiderTrax; Westin Safari Bar; KC 600 Series HiLites; Rock Rails; Smittybilt TL Guards; Smittybilt Blk Hitch Shackle w/Lock; H.O. Intake/Spectre Cone Filter.
WJ Freak is offline
post #17 of 27 Old 06-04-2010, 08:40 AM
SpinOut123
The red 'n tacky will last a few weeks if even that long. Do yourself a favor and install that bolt on the frame side in the other direction. That way you don't have to remove your bump stop when you have to grease it again. It looks like the only way to get "rid" of the trackbar squeek is to install a grease zerk. Let me know how it goes.
SpinOut123 is offline
post #18 of 27 Old 06-20-2011, 09:22 AM Thread Starter
BreadsWJ
A few updates
So, I've done a couple of changes to the WJ.
Sold my chrome clads and got some JK Moab's that I painted dark graphite metallic. Clay bar'd and waxed her up.
Hopefully, by end of weekend I should have my 4" lift on, my roof basket on, my Westin safari bar with 6" KC Hilites on, my rear receiver d'ring shackle and......that's about it.
I'll also be installing some new spring isolators, new rear A-arm ball joint, brand new Akebono calipers with Stillen Rotors and Pads from Kolak.
Always a work in progres........
http://img191.imageshack.us/img191/433/61929775.jpg
http://img823.imageshack.us/img823/9174/92463279.jpg
http://img193.imageshack.us/img193/2559/38674149.jpg
http://img189.imageshack.us/img189/654/88981238.jpg
http://img638.imageshack.us/img638/745/57353445.jpg
http://img17.imageshack.us/img17/7430/23972175.jpg
BreadsWJ is offline
post #19 of 27 Old 06-20-2011, 09:26 AM Thread Starter
BreadsWJ
pics
These are the pics
BreadsWJ is offline
post #20 of 27 Old 06-20-2011, 09:34 AM Thread Starter
BreadsWJ
Move thread please!!
Can a mod please move this thread to the proper WJ Grand Cherokee forum?
Thanks a bunch!
BreadsWJ is offline
post #21 of 27 Old 06-21-2011, 09:39 PM
sherker55
did you paint the wheels with the tires on? they look good! I've been wanting to do mine ever since I got them. I have my wheels on my accord painted that color and they look great.
Originally Posted by HaViiK View Post
Send me the number, she can take a ride in a real jeep
Originally Posted by WillMcD View Post
She said call her when your over 4"
sherker55 is offline
post #22 of 27 Old 06-21-2011, 09:49 PM Thread Starter
BreadsWJ
No, I painted them with the tires not mounted.
Stripped them to bare aluminum , scuffed very thoroughly, 2 coats of etching primer, 2 coats of filler primer, 3 coats of dark graphite metallic, then 3 coats of clearcoat.
BreadsWJ is offline
post #23 of 27 Old 06-22-2011, 09:20 AM
sherker55
all of them rattle cans? what did you use to strip the factory paint?
post #24 of 27 Old 06-22-2011, 09:21 AM
sherker55
sucks that the weights are on the outside, too bad they couldn't put them on the inside so they wouldn't be visible...
post #25 of 27 Old 06-22-2011, 06:47 PM Thread Starter
BreadsWJ
rims
Yeah, all rattle cans.
I used a spray paint stripper, worked pretty well, then I used my gas pressure washer and some elbow grease with some sandpaper to get the rest.
As for the weights, I might switch them up for the stick on's that go inside the rim when I get a chance.
Cheers.
BreadsWJ is offline
post #26 of 27 Old 09-26-2012, 04:44 AM
CruizinKev
These are the pics
these are still the 245/70-17 Hankook ATM tires you had?
- Kevin -
2000 Jeep Grand Cherokee 4.7 Dailydriver
1979 Chevrolet Monte Carlo LS3 6.2 T56 Full Resto Project
CruizinKev is offline
post #27 of 27 Old 09-26-2012, 08:33 AM
mashbolt
Sorry to ask....
But what are BPE's please?
Markie (Big Tent in the UK)
mashbolt is offline
2002 , grand cherokee , install , lift kit , rough country
