So I bought a 94 ZJ Last week... need some help - JeepForum.com
post #1 of 10 Old 12-22-2011, 12:49 AM Thread Starter
Carroll182
1994 ZJ
Hey there.
I have had a 93 ZJ for a couple years now. Its a 5.2 with 150k. Love this Jeep, but the engine has a crazy bad knock. It still has perfect oil pressure, and no loss of power/acceleration. But this isnt why im posting i guess. Though if you have any ideas id love to hear.
Now onto the 94. Its a 4.0 with 180k. Paid $2500. Its it great physical shape so i was happy with that price.
Here are the issues im having. Would love all the help i can get. After the holidays im planning on getting a lifetime membership here. Seem to like this place so far. By the way, i did use the search feature. But i need to converse with my input/observations to see it my way, lol.
1. The engine idles rough in drive... Ive read about the IAC. I cleaned it last weekend, along with a full throttle body/gas tank of Seafoam. I know some of you hate it and some of you swear by it. Thought it was worth a try, and did seem to help at first, but it came back with haste.
2. Heater want blowing hot air. Only kinda warm at best. So i flushed the heater core. Worked great! Heat worked for a few days great, but maybe its my imagination, or its just really that cold outside, but it seems to be getting cooler by the day...
3. So after flushing my heater core... DRIVERS SIDE has water in floorboard, and a decent amount. I first thought, crap...there goes my heater core. But then i remembered... thats on PASSENGERS SIDE. So hmm.. leak somewhere? I didnt really have time to track this down, and i work crazy hours during the week, so i havent gotten there yet. But i did notice the rubber grommet for the wires between my door and body is was Disconnected on the body side. So i have reseated that. Maybe the door seal is bad or something. We had heavy rain and it happened again as well.
4. Windshield wiper delay setting doesnt work... its either low through all the delays and low, or high. No idea on this, maybe i just need a know blinker arm control. Or is there a relay?
5. The rear window wiper doesnt seem to press against the window, its lazy, it just rests about an 1/8" from the window. I noticed a spring behind it, maybe i could just replace that?
6. I noticed a hose coming right off the top of the engine in the back, i think brake booster cable(?), was completely disconnected. So i kinda just shoved it back in and seems to be holding, not sure what kind of problems that could have caused.
7. My 93 had a digital VIC, but my 94 doesnt, how hard is it to switch them over if i dont have both connections in the 94? Maybe its in there somewhere and i just need to dig for it?
8. I changed the air filter and noticed a small amount of oil pooled in a spot where a hose comes into the air box, is this normal?
9. My 93 has powered seats, and my 94 doesnt, how hard would these be to change over, does it have the connector under the carpet still or is this something id have to run myself?
I think thats all for now.
I am willing to use the 93 for parts for the time being on things applicable to this.
Thank you for reading, i know its long, but im just really loving these Jeeps right now and want to get at least one of them running great so it will last as long as possible,
Josh
Carroll182 is offline
post #2 of 10 Old 12-22-2011, 01:27 AM
Glued2aPost
5. I had the same problem. Some WD40 on the spring and hinge helped, a new spring would help more.
My ZJ has never been stuck, it was just taking a break from being so awesome!
Glued2aPost is offline
post #3 of 10 Old 12-22-2011, 01:48 AM
Candymancan
Originally Posted by Carroll182 View Post
Hey there.
Get some grease or some kind of lube and lube the spring up or get a new wiper arm.. Or just bend the metal arm like i did to mine and it works great now.
If you have oil coming through that hose then that means your PCV system is clogged or not working. Go to the other valve cover passenger side.. Replace that hose and the PCV valve and the problem should go away.
Josh
As for the rest i dunno
Candymancan is offline
post #4 of 10 Old 12-22-2011, 01:49 AM
ONeil1234
#1, my rough idle got alot better when i changed my spark plugs, cap, rotor. Its runs very smooth for me now. try that.
ONeil1234 is offline
post #5 of 10 Old 12-22-2011, 03:12 AM
93zjbums
2: possibly replace the thermostat then reflush the whole system as there may be stuff in the engine not just the heater core and it may have replugged the heater core.
6: hose on the back is for the pcv and without that being connected can cause your rough idle as you were leaking vacuum and can also cause the oil in the air filter housing
93 zj laredo 4.0 with k & n intake 2 inch bb skyjacker shocks and 31 bfg at
92 chevy cheyenne 4x4 w/t with 32in procomps "The Beast" 184k
92 honda accord ex
92 xj stock 358k miles wifes
93zjbums is offline
post #6 of 10 Old 12-22-2011, 05:18 AM
cdaniels85
5. You need a new wiper arm. They aren't very expensive and are easy to replace. Just hit the spot where it connects to the hatch with some penetrating oil and you'll make life easier.
cdaniels85 is offline
post #7 of 10 Old 12-22-2011, 11:44 PM Thread Starter
Carroll182
1994 ZJ
Thanks for all the help so far. I will try all this soon.
Keep em coming!
post #8 of 10 Old 12-22-2011, 11:55 PM
mxracer12
check for water leaks at the top of the windshield. the ureathane holding the glass in comes unstuck from the body and leaks.... it is a common problem with most dodge and jeep products
mxracer12 is offline
post #9 of 10 Old 12-22-2011, 11:58 PM Thread Starter
Carroll182
1994 ZJ
How do i test that? because i think id notice the water on my dash if this were the case?
post #10 of 10 Old 12-23-2011, 12:18 AM
hdrocknroll
Here is link for wiper delay problem,Ignition Pulse Wiper Module Repair Project , these are known for going poop
http://www.jeepforum.com/forum/f13/i...roject-279739/
Always !! Keep A Firm Grip On Your Tool !!
Watch Out For The Air Hose Gone Wild!! Or Wear A Cup,: True Story
Originally Posted by rooster51 View Post
Whats the worse that can happen? Your jeeps already broke.
hdrocknroll is offline
heater , idle , questions , water
Getting my WK this week or next week. CGrugger WK Grand Cherokee & XK Commander Forum 13 04-12-2011 03:36 PM
Looking at a ZJ this week: what to look for? douglobue ZJ Grand Cherokee Forum 8 12-26-2010 08:35 PM
Some mods to the WJ this week. savexourxship ZJ Grand Cherokee Forum 10 08-20-2009 09:14 PM
First Week w/ my 5.9 murt ZJ Grand Cherokee Forum 4 04-24-2005 08:25 PM
What a week 2jeeps2many ZJ Grand Cherokee Forum 0 02-21-2002 10:32 PM
