smoking brakes?! - JeepForum.com
post #1 of 8 Old 03-27-2013, 03:43 PM Thread Starter
1995OrvisJeep
smoking brakes?!
I was on ghr freeway when I suddenly smell something burning. I iginored it thinking it was the car infront of me. Drove in the city for a bit and a lot of resistance from the car. Got home and my front drivers side wheel was smoking like crazy! Took the wheel off and replaced the caliper ($20 @ autozone) hopefully this fixes the problem
Any input?
1995OrvisJeep is offline
post #2 of 8 Old 03-27-2013, 06:13 PM
Technohead
Happens all the time.
Quite often soon after replacing pads and rotors. This is why I always replace pads, rotors, and calipers at the same time these days.
-Eric
Technohead is offline
post #3 of 8 Old 03-27-2013, 06:23 PM
zjosh93
You might want to keep an eye on it for awhile, often when the caliper sticks like that the problem is actually the hose. The hose can also be damaged by the overheated caliper. The inner liner breaks down and lets fluid by under the large amount of pressure from the master cylinder but cant get back out as easily. I saw this all the time back when I sold parts and it happened on my sister's car once. Replaced the caliper and it still was overheating, replaced the hose and fixed it.
zjosh93 is offline
post #4 of 8 Old 03-27-2013, 06:53 PM Thread Starter
1995OrvisJeep
Thanks for the input
post #5 of 8 Old 03-27-2013, 07:22 PM
Technohead
I just had this happen a few weeks ago on my tow rig.
-Eric
post #6 of 8 Old 03-27-2013, 08:07 PM Thread Starter
1995OrvisJeep
Yeah now I know how much parts are for Jeeps I might just replace everything
post #7 of 8 Old 03-28-2013, 09:45 AM
Myusername1674
I had this happen to both calipers in the front once (a week or so after i'd sunk the front end in a muddy creek and had it stuck for an hour) it ended up just being the calipers, I replaced both and now a year later no problems.
95 FiveTwo ZJ, DD, Lifted, Locked on 35s,
(in progress)
Myusername1674 is offline
post #8 of 8 Old 03-28-2013, 05:12 PM
durango-bob
2006 WK
Bleeding out all the old fluid will help keep the inside of the calipers from rusting. Old fluid will have moisture in it. Another issue is that the pads can hang up on the divots that form in the knuckles. If you have deep divots, you should replace the knuckles or weld and grind the bad area.
durango-bob is offline
