Smoke coming through the air filter!?? - JeepForum.com
post #1 of 6 Old 11-10-2007, 06:00 PM Thread Starter
avs262
I have a question. I got in my 95 Jeep Grand Cherokee today, and right when I pulled out of the driveway, it died on me. I tried starting it a couple of times, but nothing. The engine will turn, but won't start. The starter is good, everything looks good. Except one thing...I opened the air filter case, and smoke was coming back up threw the air intake. I then took off the air filter, all the way down to the exhaust manifold, and tried starting again. but it won't start. Smoke is coming out of the exhaust manifold.
Does anyone know why this could be happening? A quick reply would be nice..I don't want to leave it outside overnight.
Thanks!
Jeff
avs262 is offline
post #2 of 6 Old 11-10-2007, 06:10 PM
BucYouUp68
Are you getting Spark?
Why is there a fish finder in your Jeep?
Not hard, if you have a socket wrench and the mental capacity of a ham sandwich.
BucYouUp68 is offline
post #3 of 6 Old 11-20-2007, 04:05 PM Thread Starter
avs262
Yes, it's getting spark. I changed the cps, checked the fluids, but still won't start. All the belts are in good condition too.
avs262 is offline
post #4 of 6 Old 11-20-2007, 04:10 PM
MuddyLuxury
MuddyLuxury's Avatar
you mean you took the air filter off down to the intake manifold? and smoke is comming out? sounds like you have some serious carbon build up and your timing is off, like the intake ports are opening on the exhuast side and possibly vise versa.
-Jeb
99 WJ 4.7V8 selc-trac swap
285s re-tread
IRO 6.5 Long Arms
Aussie Locked Rear
in the works... lots deployments are great for jeep budgets
Go Doorless!
Things i need..
good spots in the mid atlantic to camp, hike, fish, kyak and wheel, if you know please share
Originally Posted by 5.9 ANDY
i would do the rear.
MuddyLuxury is offline
post #5 of 6 Old 11-20-2007, 04:19 PM Thread Starter
avs262
Yes, when it first happened I took off the air filter all the way to the exhaust manifold, and smoke was coming out when I tried starting it. It doesn't come out anymore but that's because I only try starting for a couple seconds and not for a long time.
Thanks for the advice, I'll check for carbon build up around there.
avs262 is offline
post #6 of 6 Old 11-20-2007, 04:25 PM Thread Starter
avs262
After changing the CPS, does something need to be reset?
avs262 is offline
mist/smoke coming out of A/C Vents and Dash vents scambi ZJ Grand Cherokee Forum 13 06-25-2015 12:45 AM
Cone *air* filter pre-filter wrap; Useful? coultond WK Grand Cherokee & XK Commander Forum 6 09-18-2009 01:14 PM
GC starts but dies after 3-5 mins, white smoke coming from intake box AceOfShade ZJ Grand Cherokee Forum 16 08-24-2009 04:24 PM
Dana 35 (3.55) burning 90wt oil smell and smoke coming from diff. housing/drvshft EclecticGP ZJ Grand Cherokee Forum 6 11-02-2008 07:04 PM
Smoke coming from top of oil pan. COULD IT BE BAD GASKET? jpl800 ZJ Grand Cherokee Forum 2 09-18-2008 09:24 AM
