Smells like teen spirit.. - JeepForum.com
post #1 of 11 Old 12-07-2011, 05:43 PM Thread Starter
EYPUFF
EYPUFF's Avatar
And by teen spirit, I mean coolant.
For the past 6 months or so, the interior of my jeep has smelled like coolant. I'm thinking the heater core is to blame, but I just need someone to confirm it.
Here are the symptoms:
1.) Constantly smells like coolant.
2.) Smoke/Vapor comes through vents and fogs up windshield.
3.) Heater barely works, more lukewarm than hot.
4.) A/C doesn't work. (I get the ER message at every startup.)
Number 4 probably has nothing to do w/ the heater core, but I thought it might help. So any thoughts?
And if my suspicions are correct, how hard (read: pita) will it be? Any brands I should avoid? And anything I should do while I'm in there?
Thanks for all your help!
EY
1995 GC 5.2 Limited V8
Green Jeep Club Member # 32
EYPUFF is offline
post #2 of 11 Old 12-07-2011, 06:37 PM
Candymancan
heater core is bad, replace it. That or the hoses going to it. but most likely the heatercore.
Candymancan is offline
post #3 of 11 Old 12-07-2011, 07:55 PM
phitmein
phitmein's Avatar
Is the lower part of your winshield above the vents getting a oily looking sheen to it that you can't wipe off easily with a paper towel?
If so it's the heater core.
They are no fun to replace on a ZJ because the dash has to be removed I think.
phitmein is offline
post #4 of 11 Old 12-07-2011, 09:07 PM
freakinheep89
Get an FSM before you do anything as far as removing the dash goes. Before I did it I would take it to an AC shop to have the HVAC system evac'd so you can replace the evaporator while you're in there. Not completely necessary but its such a poison to remove the dash its best to knock out whatever you can while you've got it apart.
TJ-
95 ZJ 5.2- D30/XJ shafts/D35 Yukon alloys,249, 2"BB, 30x9.5"Wildcat EXT,lots of motor mods, rancho shocks & stabilizer.
Originally Posted by slayercr23 View Post
How would i go about Stroking it?
freakinheep89 is offline
post #5 of 11 Old 12-07-2011, 09:59 PM
low_blazer
Definately sounds like the heater core is gone...
low_blazer is offline
post #6 of 11 Old 12-07-2011, 10:26 PM
squazz
heater core it is, did mine in 10 days and that was with a week hospital stay so 2 long days will get it done I recomand buying a box of zip lock baggies cuz there are about 100 screws that need to come out and your not gonna remember where they all go so bagem and tagem
squazz is offline
post #7 of 11 Old 12-07-2011, 10:34 PM
phitmein
phitmein's Avatar
Freak is 100% right and if you do try to do it yourself never work on a dash without a disconnected battery cable because of the danger of setting off the air bags.
If your Jeep were any newer then I bet you would be told to think about replacing the blend door thingy too.
It is a very hard job to do and if it was mine I would do it but pulling my engine would probably be easier.
phitmein is offline
post #8 of 11 Old 12-08-2011, 07:21 AM
longne
I just did this job on my 96. Its not as hard as it sounds, just be ready to dedicate a weekend to it. Do both the heater core and the A/C Evaporator to save yourself from having to do the job twice. It took me a few hours to get out the air box and after replacing the cores it was pretty easy to get it all back together. You'll probably want an extra set of hands to slide the dash off and to put it back. Other than that, its just tedious. I do suggest a panel popper and plenty of different size socket extensions. There is a step by step guide somewhere on the site, it will help to figure out where to find screws and bolts.
longne is offline
post #9 of 11 Old 12-08-2011, 01:26 PM Thread Starter
EYPUFF
EYPUFF's Avatar
Haha. Yes. The oily windshield has always been annoying.
EYPUFF is offline
post #10 of 11 Old 12-08-2011, 01:27 PM Thread Starter
EYPUFF
EYPUFF's Avatar
My A/C hasn't working in years.. is it because of the blend doors & A/C evap?
EYPUFF is offline
post #11 of 11 Old 12-08-2011, 05:31 PM
longne
Likely there is corrosion on both the evaporator and the heater core. Leaves and junk get into the box through the air intake from outside. Its likely that if you replace the evap, you can get the A/C up and running.
longne is offline
smells itsmyheep2 ZJ Grand Cherokee Forum 7 09-01-2011 09:24 AM
New Jeep smells like gas...Bad! JohnnyChuttz WK Grand Cherokee & XK Commander Forum 3 01-07-2011 11:32 AM
WK CRD smells AJ+SJ WK Grand Cherokee & XK Commander Forum 23 11-04-2008 12:14 PM
Oil Smells like gas jbrink ZJ Grand Cherokee Forum 9 06-18-2008 04:45 PM
Air smells really bad! 95_Jchke ZJ Grand Cherokee Forum 6 09-10-2006 05:34 PM
