smelling gas - JeepForum.com
post #1 of 3 Old 12-24-2002, 01:46 PM Thread Starter
Big Dumb White Guy
Big Dumb White Guy's Avatar
smelling gas
4.0l I6
it takes longer to start -(no more than 5 seconds though). used to just twist the key and VROOM!! now it takes longer and there is a slight smell of gas (inside the vehicle). it goes away after a few seconds. no trace of fuel on the ground. plus gas milage has gone right down the toilet. it's got to be fuel related (starter is just fine). fuel pressure regulator? fuel pump? bad injector? any ideas or things to check???
repost Nazi's suck!
A guy walks into the psychiatrist office wearing only Glad Wrap shorts. The shrink says, "Well, I can clearly see you're nuts."
Big Dumb White Guy is offline
post #2 of 3 Old 12-25-2002, 05:51 PM
MJR
MJR's Avatar
1988
If you have a gas smell then something would be leaking. It could be fuel injectors, seals, etc... It maybe small enough to evaporate before you see it dripping. Just look it over real good.
"Got Groceries"
88 Jeep Wagoneer
MJR is offline
post #3 of 3 Old 12-25-2002, 06:01 PM
Ryan2son
I would check the vacuum lines (sounds like your engine "thinks" there is a fuel/air problem and has increased the fuel mixture (hense the fuel smell and poor gas mileage)...
Richard
1999 Jeep Grand Cherokee Laredo
4x4, 4.7 V8, Quadratrac II, Loaded
A Hail the Mighty Philadelphia Eagles!
Ryan2son is offline
My turn with an A/C issue - smelling freon inside cabin Cebby WJ Grand Cherokee Forum 17 06-02-2013 10:02 PM
Smelling Gas? Misfiring or regulator? chourki ZJ Grand Cherokee Forum 3 11-11-2005 08:31 AM
smelling antifreeze...heater core??? scottjclaypool ZJ Grand Cherokee Forum 1 01-21-2005 09:42 AM
