Smell gas in my oil - Page 2 - JeepForum.com
post #16 of 24 Old 11-23-2011, 07:24 AM
rlcii77
How old is your O2 sensor? Before I changed mine out, I noticed some "black" smoke at idle after a minute or so, and really seen some when I got on it. My oil also had the gas smell in it until I changed the O2 sensor. Just a thought since nothing is being thrown in your kettle.
'72 CJ5 Ren
'91 XJ, '96 XJ, '98 XJ
'94 ZJ, '96 Orvis ZJ
'98 Platinum 5.9, '98 Slate 5.9 (DD)
rlcii77 is offline
post #17 of 24 Old 11-23-2011, 08:48 AM
somebody5788
1994 ZJ
With 3000 miles on the oil gas smell is very common. It's honestly rather rare that we do an oil change at the shop and there isn't a little gas smell. If you live in town and do a lot of short trips it is going to happen even if the car is brand new. Now if it's got a distinct gas odor after like 1500 miles that's a problem.
The reason for the short trips thing is because if the engine and oil don't get up to full operational temp everytime you drive it then there is no time to burn off or evaporate any of the gas that gets into the oil. Under optimal conditions the gas evaporates and goes through the PCV to the intake and burns off.
2006 Honda 919 - Summer Daily
1994 Jeep ZJ - RC Long Arms | RE 4.5" springs | Bilstein 5100's | RE SS brake lines | Falken 31x10.5-15 tires | Flatland 4x4 bumpers | Summit Soft 8's 15x8 3.75 BS wheels
somebody5788 is offline
post #18 of 24 Old 11-23-2011, 09:35 AM
wsar10
2003 WJ
^this is very true, you can always tell on a UOA when somebody does alot of short trips becuase they have high fuel dilution. Also long idling will cause this.
QUOTE=billzcat1;wsar10 is right on point on this oil thread - as usual. Anyone reading this would be well-served taking his advice.
-03 WJ laredo 4.0 120k a few minor mods
-93 XJ 5spd, 3" zone lift
wsar10 is offline
post #19 of 24 Old 11-23-2011, 09:52 AM
badbird17x
badbird17x's Avatar
1994 ZJ
My 5.2 was loosing op, and gaining oil. I replaced all the injectors to fix it. I'm not gonna say this is for sure your problem. Mine also would act hydro locked after letting it sit a bit, so I knew it was injectors. You could have an o2 issue. I put 32lb injectors in a car needing 26lb once, it's oil stunk of gas in 30 miles, so the computer may be throwing to much fuel at it.
94 jz, bruiser, la, cage,5.3 ls, 36 swampers 98 jz, the mutt, 3.5 iro, 33 swampers, avalanche conversion, 02 north face avalanche blacked out work truck, 06 rhino R1 engine, 4x4, Leeroy's custom paint, 04 escalade wifes truck 22s, 03 duramax 18s, completely blacked out, efilive by nick, wicked wicked truck, 39 chop chevy rod, aluminum 5.3 ls, 08 apex, 310hp mcx turbo, holz 162, completely black, CCM built.
badbird17x is offline
post #20 of 24 Old 11-23-2011, 10:52 AM
PolkaPower
Do you smell it on the dip stick or in the crank case?
PolkaPower is offline
post #21 of 24 Old 11-23-2011, 11:17 AM Thread Starter
speedbucket
Dipstick. I'm in Kentucky right now for Turkey day. Just seemed thin when I checked level. So I smelled and smelled of fuel. Those injectors are original equipment
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #22 of 24 Old 11-23-2011, 11:29 AM
PolkaPower
My crank case smells a little like gas vapors but if you smell it on the dip stick then it's possibly a stuck open or leaky injector. Is the oil level higher than usual?
post #23 of 24 Old 11-23-2011, 11:54 AM
wsar10
2003 WJ
either way I would get that oil out of there asap, even if you replace it with just cheap dino it's better than tampered with viscosity and TBN.
wsar10 is offline
post #24 of 24 Old 11-23-2011, 12:49 PM Thread Starter
speedbucket
I have a bad Plenum gasket and she Burns half quart every 800-1000 miles
gas , oil
Smell of gas around car Breathe ZJ Grand Cherokee Forum 3 08-29-2010 09:00 AM
Ooh, that smell! ZeJokee ZJ Grand Cherokee Forum 3 08-23-2009 09:05 PM
I smell oil cweb ZJ Grand Cherokee Forum 9 04-19-2008 09:39 PM
Gas Smell!! JeepRagan ZJ Grand Cherokee Forum 6 10-03-2007 05:29 PM
Bad Smell wreck76 ZJ Grand Cherokee Forum 6 11-26-2004 04:37 PM
