Smell of gas? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Smell of gas?
FS: Wranger BRIGHT License Plate LED! Just $3! Great valuePANDEMIC-USA 50" Double row LED LIGHT BAR!! These thiFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 07-27-2015, 01:03 PM   #1
Bman1337
Smell of gas?
occasionally ill get a smell of gas in the cabin also when i get out its there for just a couple seconds,
Are these jeeps known to have any gas leak problems? or is the smell normal?
its not super strong, but i can tell its there.
Bman1337 is offline   Reply With Quote Quick reply to this message
Unread 07-27-2015, 01:03 PM   #2
Candymancan
probly have an exhaust leak somewhere
2013 6.2 V8 Camaro SS 9k miles
1998 5.9 V8 ZJ 180k miles
1998 4.0 I6 Laredo ZJ 227k miles
Candymancan is online now   Reply With Quote Quick reply to this message
Unread 07-27-2015, 02:20 PM   #3
1stblack97ZJ
Most likely the exhaust manifold is cracked. Common 4.0 problem.
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
1stblack97ZJ is offline   Reply With Quote Quick reply to this message
Unread 07-27-2015, 04:19 PM   #4
coralman
I can wish can't I?
coralman's Avatar
Eyeball the fuel rail quickly after you get out. Could be a leaking injector oring, but the gas evaporates instantly on a hot motor.
http://www.jeepforum.com/forum/f13/c...-faqs-2863665/
coralman is offline   Reply With Quote Quick reply to this message
Unread 07-27-2015, 08:21 PM   #5
Bman1337
i know it has a cracked header. so thats it i assume
Unread 07-27-2015, 11:28 PM   #6
green98ZJ
Yeah there's your problem. I think my 93 has the same problem but I smell gas and oil lol. At 168xxx miles even.. I really smell it when I let off of the gas at highway speeds
98 Laredo 4.GO, 373s, Magnaflow//93 Laredo ax-15 that hauls a$$, but isn't a lady killer(TheTurd)
green98ZJ is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 12:15 AM   #7
Uniblurb
Uniblurb's Avatar
Hmm.. thought you would have mentioned that in your other thread..
What happens is air will enter the cracks in the header, the o2 sensors picks up to too much oxygen passing this onto the PCM, which in turn signals the injectors to dump more fuel in for a lean condition, and the fuel mixture ends up way too rich. Hence the smell of fuel which will eventually clog the cat.
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 93 4.0 XJ (spare), 96 4.0 XJ (son's)
-Stalling ZJ? 12 things to check before replacing a sensor; the Dirty Dozen
-Crankshaft position sensor multimeter test. & video of testing.
Uniblurb is online now   Reply With Quote Quick reply to this message
Unread Today, 12:58 PM   #8
Candymancan
Luckily on the 4.0 it isnt hard to replace.. I would get a new one or one from a JY and fix it..
