Slight steering clunk - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Slight steering clunk
1987-1989 Jeep Wrangler Front Wheel Bearing & Hub Asse1990-1995 Jeep Wrangler Front Wheel Bearing & Hub AsseSmoking Deal on Jeep Slip Yoke Eliminator Kit with rear 13
Unread 04-05-2006, 04:37 PM   #1
gdupjeep
My 5.9 is getting making a slight clunking sound when I steer (usually at speeds over about 35). It sounds like metal on metal and is very distinctive. It is somewhat random and happens with slight movement of the steering wheel. I don't have to actually be turning to produce the sound....it's usually happens while making slight adjustments to the steering wheel while driving in a straight line. I'm currently at 5.5" of lift and have all the adjustable control arms, adjustable track bars, etc.
Any ideas?
gdupjeep is offline   Reply With Quote
Unread 04-05-2006, 04:55 PM   #2
FPKites
ZJjazzyJim
FPKites's Avatar
How about your tie rod/drag link ends? Any slop?
Jim Karlin
"Duh! Big RED Jeep!!!"
Best mod you'll ever do on ANY vehicle!!!!
FPKites is offline   Reply With Quote
Unread 04-05-2006, 05:04 PM   #3
CrawfishStu
How about your bolts that hold in your steering box. Three bolts in your wheel well.
95ZJ, V-8, 231, HP30.LockRight, D44A.Aussie, 8" Rusty's LA, 35x12.5 MTZs, Custom Sliders, Rusty's TC Skid, ARB Front Bumper, Tomken Rear Bumper, Phat Jeeps Steering, + More.
CrawfishStu is offline   Reply With Quote
Unread 04-05-2006, 06:53 PM   #4
Varkyl
No where near stock
Varkyl's Avatar
Check the bolts in the Track bar as well.
Nathan
One slightly modified '96 ZJ
new sig coming soon
Varkyl is offline   Reply With Quote
Unread 04-05-2006, 07:13 PM   #5
JeepZJ
yes track bar will clunk if not tight
JeepZJ is offline   Reply With Quote
Unread 04-05-2006, 10:19 PM   #6
Scooter932
Is the "track bar" the same thing as the sway bar? Just trying to clarify, I think its just a difference in terminology.
Scooter932 is offline   Reply With Quote
Unread 04-05-2006, 10:22 PM   #7
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Nope, the trackbar centers the axle. It connects to the frame on the drivers side and to the axle on the passanager side.
ArloGuthroJeep is offline   Reply With Quote
Unread 04-06-2006, 01:23 AM   #8
gdupjeep
The track bar needs to be adjusted actually. I'll find out if that is the problem tomorrow when I take it in. I had it lifted up to 5.5" and they forgot/neglected to center the axle properly. It's off about an inch to the right.
Unread 04-07-2006, 12:04 AM   #9
gdupjeep
Can you elaborate? Which side, inside or from engine compartment?
Thanks!
It turns out it was not the track bar since I had it adjusted and it still clunks. It's actually getting worse now.
Unread 04-07-2006, 06:46 AM   #10
CrawfishStu
They are on the outside. Look inside your wheel well above and in front of the tire on the driver's side. Two of them are easy to see. Those are the bottom two bolts. The other bolt is about 3 inches above that and a litter further to the left. You will need a 3/8 ratchet or box end wrench. From the factory they are locktited. If it is loose pull the bolt and re locktite them one at a time.
