Slight leaks on my GC 1998 ORVIS - JeepForum.com
post #1 of 1 Old 05-14-2013, 09:42 AM Thread Starter
mark2828
Hi all little bit of advice if poss
I have just booked my GC ORVIS 1998 in to have the Front wheel bearing hub changed , Rear wheel bearings chaged , Rear main oil seal changed and the Front CV Boot changed
On top of this little lot I have a slight leak on the gearbox sump and Transfer box
The Leaks are only slight and are not affecting the drive .... well i think it doesnt as the bearings and CV boot were causing some clunking noises so hard to tell !!!!
Anyway are the leaks something that i could put right over the next couple of months or should i get them looked at sraight away
any advice would be appreciated
thanks
mark2828 is offline
