Slamed on brakes now no brakes? - JeepForum.com
post #1 of 8 Old 09-15-2008, 08:54 PM Thread Starter
94ZJLaredo
1994 ZJ
Ok i was on my way home and i was comming up to an unexpected yellow light so i slammed on the brakes. on the way home i knowticed my brakes went to the floor so i took it easy. finally getting home i opened the hood and discovered i had no fluid in front part of the BF container and full in the other. the rear brakes are new, the front needs replaceing soon. the container is now full on both ends but i still have no brakes and i pumped the brakes constantly but the fluid goes nowhere and all lines are new and tight i have a 94 Grand Cherokee Laredo, has the 249 Tcase, Automatic and a 178,000mile straight 6 just for info.
94ZJLaredo is offline
post #2 of 8 Old 09-15-2008, 08:57 PM
Windowsrookie
Sounds like you blew something, either a line or a caliper. Check them for leaks.
2000 Grand Cherokee Laredo 4.7L V8 Quadra-Drive
1987 Wrangler 4.2L
Windowsrookie is offline
post #3 of 8 Old 09-15-2008, 08:57 PM
Dillonzj
sounds like you need to bleed your brakes
98' JEEP GRAND CHEROKEE LIMITED 5.9
149k 5.9L v8 White
Crane Cam shaft and Crane, Roller Rockers, bored .030 over, edelbrock performer heads, M1 Intake manifold, Fasstman throttle body, magnacore wires, platinum plugs, K&N FIPK, dough thorley headers,3" high flow cat, 3" magnaflow mandrel bent exhaust, SCT tuned
***future mods -5.5 IRO LA - KOR sliders -KOR roof rack -
SOLD-
95' JEEP GRAND CHEROKEE LIMITED
188k 5.2L v8 White 98 ZJ rims
Originally Posted by nashmd454 View Post
...we all know they empty our pockets...yet they fill our hearts...
Dillonzj is offline
post #4 of 8 Old 09-15-2008, 08:58 PM
the88thpianoman
2003 WJ
Check inside the brake booster behind the master cylinder, see if there's fluid in there. You might have blown out the seal on the back of the master cylinder, which also would have introduced air into the brake lines.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #5 of 8 Old 09-15-2008, 08:58 PM
Yardman Harry
O
Yardman Harry's Avatar
Agreed... also, check for leaks a previously stated, then bleed your brakes.
Harry
1996 Jeep Grand Cherokee. V8 - 5.2 litre 242 SelecTrac. SURCO Safari Roof Rack
Hunter Green
1997 Jeep Wrangler Sahara Ed. I6 - 4.0 litre, 4" SL, D44 rear, 4:56 Gears, AA SYE with double cardon custom rear Drive Shaft, IRO Adj CAs, Kevins Rear Adj TB with JOHNNY JOINT end
1999 Mazda Miata MX5 - Jet Black
1990 Jeep Cherokee Sport I6 - 4.0 litre
White
~Junked~
Yardman Harry is offline
post #6 of 8 Old 09-15-2008, 09:02 PM Thread Starter
94ZJLaredo
1994 ZJ
will do. thanks for the info.
post #7 of 8 Old 09-15-2008, 09:02 PM
SnowdogMarc
Check your rear brakes. Sounds like you blew a seal or line somewhere. If I'm not mistaken the front part of the resivour is for the rear and the back for the front. Whichever is the larger part that is for the rear. I did the exact same thing awhile back in my truck and even after I put fluid back in you have to crack the line to get the fluid to flow again. Start at the wheel closest to the master cyl and work to the farthest last. It helps to have a buddy around to help.
l We're here for a good time. Not a long time. So have a good time the sun can't shine every day.
l_______
/l ,[_____],
l---L -[]lllllll[]-
()_) ()_)--o-)_)____________VE6-SDG
SnowdogMarc is offline
post #8 of 8 Old 09-15-2008, 09:07 PM Thread Starter
94ZJLaredo
1994 ZJ
well its 8.04PM here, dark and i really dont feel like going out LOL tomorrow morning i'll look into it. i hope i dident blow out anything. i just spent roughly 75 bucks on fixin the rear brakes and replaceing studs and lugs along with all the hardware for the rear brake assembly. "springs, adjusters, ect." I HATE BRAKES!!! but i love jeeps LOL. sorry rough day
New brakes, again.... kwb18 ZJ Grand Cherokee Forum 19 03-31-2008 12:04 AM
Upgrade WK brakes to SRT-8 brakes? Gannet WK Grand Cherokee & XK Commander Forum 3 12-11-2007 08:43 PM
GC Brakes GC4L2000 ZJ Grand Cherokee Forum 3 03-23-2007 12:31 PM
Brakes djdoug99 ZJ Grand Cherokee Forum 0 02-28-2007 06:24 PM
Need Help with 99 Brakes Myrtle Beach ZJ Grand Cherokee Forum 17 10-25-2004 06:28 PM
