Skid Plates - JeepForum.com
post #1 of 3 Old 06-29-2004, 01:40 PM Thread Starter
wreck76
wreck76's Avatar
Skid Plates
I gots a '02 GC that doesn't have skid plates (well, it has a gas tank plate). Just wondering if it is better to buy the Jeep plates or to get after market. And how hard is it to put two hooks onto a GC that does not have them? Front and back
wreck
wreck76 is offline
post #2 of 3 Old 10-19-2004, 07:21 AM
Diehard
Diehard's Avatar
Hi. I know this is a late reply, but just joined and saw it. I ordered my plates from Wyckoff. You can do it online. You probably have them by now, but if you don't they are the least expensive and are Mopar parts same as oem parts. The transfer case plate is $35.10, the front plate is $44.10 and if you need tow hooks they are $86.40 for the front pair. If you have a tow hitch you really don't need the rear tow hooks. Also the fuel plate is $139.50. Except for the fuel plate they all come with instructions, the fuel plate just bolts up using the bolts for the hitch,which you have to drop or remove, and fuel tank. As far as the front tow hooks, on my 2004 GC, you'll have to take off the front fascia, grille and bumper, to correctly install them. If you don't have the hitch in back the rear ones just bolt up to the frame and have a bracket to help support them. I hope this helps even tho it is a little late. Vince
Diehard is offline
post #3 of 3 Old 10-19-2004, 08:36 AM
Chrisca
Chrisca's Avatar
That's about what I paid for the hooks and the two front skids. The Mopar plates are good (& cheap) enough.
Don't worry about the gas tank plate. The stock one is good enough. (If you needed something else, you wouldn't have to ask.
I recommend getting a Mopar hitch instead of a rear tow hook. You can get one from a junkyard for ~$75 vs. ~175 new.
2004 Grand Cherokee Laredo
Chrisca is offline
zj skid plates grandpapy ZJ Grand Cherokee Forum 5 01-16-2008 01:15 PM
Skid plates? Hi Its Me Sami ZJ Grand Cherokee Forum 18 05-21-2007 03:15 PM
Skid Plates tsuji ZJ Grand Cherokee Forum 13 08-18-2006 08:20 PM
WJ Skid Plates 02wjeep ZJ Grand Cherokee Forum 1 06-01-2006 10:58 PM
Skid Plates? bearlax4 ZJ Grand Cherokee Forum 5 05-29-2006 08:03 PM
