Skid Plate? - JeepForum.com
post #1 of 13 Old 07-07-2011, 11:20 PM Thread Starter
Newb1995jeepgc
1994 ZJ
Skid Plate?
Well today after shopping around the jy and found a Skid Plate off of a Junked ZJ that had a under hood fire. So i looked underneath it and it had the stock skid... so i want to ask this is 25 dollars a good price for it?
1995 Jeep ZJ Limited V8- 213k- sold
2000 Jeep WJ I6- 185xxx-sold
1994 Jeep ZJ Limited Red I6- 210k
Newb1995jeepgc is offline
post #2 of 13 Old 07-07-2011, 11:32 PM
Oldfrog
2007 WK
For all three skid plates? Yes !
Be careful when removing the front one. If you arent ready for it, it likes to break noses.
( for the record...NO...mine never fell on me ..)
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #3 of 13 Old 07-07-2011, 11:34 PM Thread Starter
Newb1995jeepgc
1994 ZJ
No its just the Transfer Case skid plate... but it was only 25 bucks but i need the bolts to it.
post #4 of 13 Old 07-08-2011, 01:00 AM
PeriwinkleZJ
I used just a nut and bolt with a locking washer. The two in the crossmember are really easy. The one in the uniframe I used a magnet to fish it to the hole. That's where the locking washer comes in, it keeps the nut from spinning so you can tighten it down. It worked for me and my brother extremely well.
-1993 Grand Cherokee Laredo V8 5.2, Mopar CAI, Borla headers, Borla Y-pipe, Turn down exhaust, 4" RC SA, 33x12.50r15 BfGoodrich Km2, Crown extended brake lines, IRO Double Shear Track bar, IRO HD tie rod, Home made Quick discos, E-fan, Heavy duty harness/9007 bulb conversion, HP30 WJ knuckles lockrite solid cover.
BUILD THREAD:
PeriwinkleZJ is offline
post #5 of 13 Old 07-08-2011, 01:39 AM
zander21510
Did the 95 Orvis come standard with skid plates? Or the limiteds? I have a laredo that im pretty certain doesn't have skid plates, and now I'm curious if theres one at my local JY for cheap...
zander21510 is offline
post #6 of 13 Old 07-08-2011, 07:00 PM
Oldfrog
2007 WK
It didnt have all three? Are you sure there isnt one under the gas tank too?
I took my front one off to do some work on mine this past spring, and just havent reinstalled it yet. That thing is so heavy, I swear my gas mileage increased...lol !
Oldfrog is offline
post #7 of 13 Old 07-08-2011, 11:24 PM Thread Starter
Newb1995jeepgc
1994 ZJ
I didnt look if it had the gas tank skid plate but I did like the fact that it had the transfer case skid and this one was a laredo.. you could get the skid on all models but it was all optional including tow hooks.
post #8 of 13 Old 07-08-2011, 11:25 PM Thread Starter
Newb1995jeepgc
1994 ZJ
Also what size bolts does it take... and how would be the best way to bolt it in?
post #9 of 13 Old 07-09-2011, 10:48 AM
stageninja
That Rigger Guy
stageninja's Avatar
You can get nutsertz from the dealer or Fastenal to install into the pre-drilled holes in the frame. There was a write up sometime ago about making an installation tool for the nutsertz.
Mine '97 White, ZJ Ltd, 5.2, Up-Country Suspension, Kolak ignition, Kolak/Magnaflow Exhaust
Her's '98 Chargold ZJ Ltd. 4.0 2wd
Our 1st '97 White, ZJ Ltd, 5.2, The parts Jeep for 5 years...R.I.P. Sent to Pic-A-Part 5/17/2013
stageninja is offline
post #10 of 13 Old 07-09-2011, 01:40 PM
gothchick
I just installed my skids this morning. Got some nice ones from the local junk yard. I didn't get the nuts and bolts to go with mine either, so I went down to the Tractor Supply to get some...
Metric M12-1.75 x 35 did the trick.
Don't fear the regear.
Finished 4x2 --> 4x4 conversion.
gothchick is offline
post #11 of 13 Old 07-11-2011, 11:45 PM Thread Starter
Newb1995jeepgc
1994 ZJ
Got the skid on... Pain in the a$$ but its on and looks good... the bolts that went in the crossmember wasnt to hard but the one that goes in the frame was a PIA. Took some wire and threaded it on the bolt and shoved it into another hole big enough to slip it through. So now its skid ready hahah. Ill take pics of it when it stops raining... anybody else Got a pic of a stock skid or aftermarket. For 25 bucks i dont think i came out of this to bad.
post #12 of 13 Old 07-12-2011, 10:18 AM
Dizasty
Pics
Dizasty is offline
post #13 of 13 Old 07-12-2011, 10:55 AM
Tudds
Thank you. I had two skids and no hardware
Tudds is offline
WH (WK) Skid plate CRD sbv20j WK Grand Cherokee & XK Commander Forum 10 02-09-2010 09:35 AM
Skid Plate BonesWK WK Grand Cherokee & XK Commander Forum 17 01-30-2010 03:43 PM
Skid Plate? NickkciN ZJ Grand Cherokee Forum 28 04-16-2008 04:45 PM
Skid plate on the way Wiley ZJ Grand Cherokee Forum 11 03-06-2006 06:22 PM
TC Skid Plate ? Smith Erick ZJ Grand Cherokee Forum 4 01-16-2006 07:57 PM
