Silencer - Kill Switch inoperable - JeepForum.com
post #1 of 3 Old 12-12-2004, 02:00 PM Thread Starter
oilcounter
I have one for you..
I have a 2000 JCG laredo and the stealership threw in their SILENCER kill switch. This has a female unit under the dash that accepts a male "pin" in order to activate the starter.
For the longest time I have just left this pin in the hole (out of convienience) Last night I decided it would be best to take ths pin with me when I leave my car in the Mall parking lot. Usually there would be a red light to indicate that the kill switch was activated when the pin is removed. Now it does nothing.
I'm pretty sure the kill switch ISN"T protecting a darn thing now....
Does anyone have any suggestions for me to check? I'm not too good with electrical stuff, but thought if there was something easy to check before I attempted to let the dealer look at it..
Thanks
Rob
2000 JEEP GRAND CHEROKEE I-6 (WJ)
All stock except for Mopar 3 disc In-dash CD player
Michelin M/S LTX 255/70/16
Metallic Taupe Jeep Club Member #15
oilcounter is offline
post #2 of 3 Old 12-12-2004, 02:06 PM
Meerkat
My Jeep had one of those in it. It didn't work right, and kept the cruise control from working, so I took it out and threw it away. Everything has been great since then.
There should not be any fuse in the circuit (if it blew, your Jeep wouldn't start). Other than checking the splices to see if one has come unplugged, the only other thing would be the control module. It should be zip-tied up under the dash, but low enough to reach. If you start at the socket and light unit and follow the wires back, they'll lead right to the module. IIRC, there are two plugs on it. One may have come undone.
HTH
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #3 of 3 Old 12-12-2004, 02:54 PM Thread Starter
oilcounter
Thanks Warren;
I looked under there and tried to follow the wide wire upwards (toward the steering column). It's tucked up there pretty far.. I'll have to remove some plastic dash board pieces to see the module..
I think WJJEEPS.com has diagrams for removal of stuff like this..
-Rob
Factory security system is trippin the kill switch. tex62 ZJ Grand Cherokee Forum 0 07-30-2008 08:49 PM
Vent Direction Selector inoperable FordPrefect ZJ Grand Cherokee Forum 4 06-24-2008 10:07 AM
Heated Seat inoperable in '02 Overland E-Dub ZJ Grand Cherokee Forum 2 10-28-2005 08:03 PM
ignition and/or fuel pump kill switch Saleen4971 ZJ Grand Cherokee Forum 2 03-21-2004 09:19 PM
acc power kill switch? mattsami ZJ Grand Cherokee Forum 4 10-02-2002 04:13 PM
