09-04-2007, 09:51 PM
#1
signs of a bad cam sensor ?
hey guys, wondering if anyone could tell me what the signs of a bad cam sensor would be in my 93 ZJ. I have long cranking times when the engine is cold and im wondering if it has anything to do with the cam sensor. (crank sensor has been replaced)
if anyone can let me know the signs of a bad cam sensor, it would be greatly appriciated
1993 Jeep Grand Cherokee Limited
Green/Gold, Tan Leather
4.0L , 42RE transmission-- 242 selectable transfer case
Bone Stock with the acception of a K+N drop in filter and my aftermarket stereo, also did alot of new tune up wear and tear parts!
366 000 kilometers and stilll runs great :)
purchased for $125 bucks, amazing daily driver for the money
09-04-2007, 11:06 PM
#2
usually a check engine code #54
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
09-05-2007, 03:24 AM
#3
I don't know if it is or will be your cam sensor, but my brother and I just went through this. If it comes down to buying one, don't go in and ask for a cam sensor. They will look at you like your crazy. It's called a hall effect sensor.
Mud is Good!
09-05-2007, 06:34 AM
#4
JEEP FREAK
Its a spark related sensor, so if your longer crank times are due to a lack of spark problem, its a possible cause.
The more likely problem you're having is with the anti-drainback valve. This valve is responsible for keeping the fuel lines primed. When it goes bad, the fuel rail will lose fuel pressure if the vehicle sits long enough.
It starts fine when its warm?
09-05-2007, 09:13 AM
#5
Cam sensor problem look like an old worn out engine ..
like low feul pressure related problems
codes are not always thrown by the obdii
the engine will stall intermintenly at times while driving
a new sensor is about 50 smakers
POLISH - CANADIAN ........... JEEP Lovers CLUB
09-05-2007, 12:47 PM
#6
yep fires up mint when warm, is this anti drain back valve hard to replace ?? i just did the fuel pump in my jeep soo low fuel pressure isnt the problem but it could be a worn out 4.0L ...it does have 380 k on it
09-05-2007, 01:42 PM
#7
well if im correct u have atleast 210k + miles on your jeep...
so it could just be worn down..
09-05-2007, 01:46 PM
#8
JEEP FREAK
I'm not sure on a 93 ZJ, but on a TJ, the anti-drainback valve is part of the fuel pump assembly in the fuel tank.
09-06-2007, 10:38 AM
#9
then agian it could just be a worn out cam shaft
and all the lifters
and other thingys
09-06-2007, 11:03 AM
#10
The IAC (Idle Air Control) solenoid might not be resetting when the engine is cold. That could not let enough air in for good combustion on cold start up. Try a cold start with the accelerator pedal pressed down a little to see if that helps.
2001 WJ Limited with Quadra-Drive, Kenne Bell Supercharger, 3-inch Kolak exhaust, Stillen rotors (F/R) and MM pads, Addco sway bars (F/R).
09-11-2007, 08:55 AM
#11
Do you hear the fuel pump prime when you turn the ignition to "ON" but don't try to start it? I had the PCM/ECM/Computer act up which didn't fire the pump. 30-45 secs of cranking would get it to start. I ended up getting a new computer from Rock Auto.
-- '93 ZJ - 4.0, 2WD, boat truck again, $250 :)
09-11-2007, 11:11 AM
#12
yeah and you have 17 on yours...
96' JGC V-8 5.2L ltd.
way too much to list.
Thought for the day:
If GOD gave HIS only son for us...can't we at least give HIM an hour of our time a day.
[URL]http://photobucket.com/albums/v639/nashmd454[/URL]
[url]http://groups.jeepforum.com/The_Dark_Side[/url]
09-11-2007, 01:46 PM
#13
The cam shaft sensor will cause it to stall while driving. Sometimes it will start right back up. Crankshaft causes it to not start especially in damp weather; fog, rain high humidity. The check valve will cause delayed starting, but if you turn the key to the on position for a few seconds, then to start, it should fire right up.
02-05-2011, 10:45 AM
#14
i have a 96 zj and it stalls in cold damp weather any ideas but it only does it when warm and while stopping?
