Sign of a Bad Wheel Bearing or Ring and Pinion Bearing? - JeepForum.com
post #1 of 29 Old 02-01-2010, 04:02 PM Thread Starter
torchd
2003 WJ
Just this morning drivng home from work, in the back of the car where the rear hatch is I can hear a noise back there. Hard to describe how it sounds. It isn't loud by any means, but obviously I heard it.
So what are the signs of wheel bearing or ring and pinion bearing goign out?
Thanks
torchd is offline
post #2 of 29 Old 02-01-2010, 04:18 PM
ZJPunk98
You will notice a somewhat loud hum from the rear of the jeep when driving at highway speeds, the noise will go away when you let off the accerator and return soon as you step on it again.
If wheel bearing were going bad, i think you would hear some type of squeek as the wheel rotates.
Erik
98 ZJ 5.2L JGC Limited Sold
02 4.7L HO JGC Overland
ZJPunk98 is offline
post #3 of 29 Old 02-01-2010, 05:00 PM Thread Starter
torchd
2003 WJ
Its necessarily a humming sound that I hear... Almost sounds like road nose like you said coming from the rear of the Jeep..
The noise is present at 35 mph till 65 mph (thats as fast as I go on the hwy).
When I let of the gas and jsut coast you can still hear the noise coming from the rear. Also today while I was driving on a back road, I was going about 40 mph, put the Jeep in Neutral turned the car off (as I was going 40) and you could still hear it..
So wheel bearing or ring and pinion bearing???? But what ever the part that is causing the noise is definitely a rotating noise
torchd is offline
post #4 of 29 Old 02-01-2010, 07:09 PM
sdowney717
it could even be a worn universal in the driveshaft. just get under their and check it out
sdowney717 is offline
post #5 of 29 Old 02-01-2010, 07:40 PM
Hexonut
all you need is a jack and a stethoscope or a broom handle and the jack under your rear seat...
Hexonut is offline
post #6 of 29 Old 02-01-2010, 08:48 PM
MurdaJs
When my rear wheel bearings were toast it made a "whirring" sound directly related to wheel speed
MurdaJs is offline
post #7 of 29 Old 02-02-2010, 08:00 PM
RobinsonFam1
pinion bearing makes noise and vibes on decelleration (letting off gas, not braking). i just went through that myself. if its constant i would suspect wheel bearing. u joint possible but from the description i lean towards wheel bearing.
RobinsonFam1 is offline
post #8 of 29 Old 02-03-2010, 02:05 PM Thread Starter
torchd
2003 WJ
The more I think about it, the more it sounds like a wheel bearing. I do know that it is definitely coming from the rear. And when I let off the gas, the noise is still present.
torchd is offline
post #9 of 29 Old 02-03-2010, 02:33 PM
Bama_WJ
Bama_WJ's Avatar
Yea, my front wheel bearing sounded the same way. Maybe had a little bit of a groaning noise in there, too.
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ
Bama_WJ is offline
post #10 of 29 Old 02-23-2010, 12:35 PM
Barrishautomoti
Did you ever find out what was making the noise in your Jeep? I have a 97 ZJ which is making the same kind of noises in the rear. Just trying to find out what needs to be replaced.
Barrishautomoti is offline
post #11 of 29 Old 02-23-2010, 02:59 PM Thread Starter
torchd
2003 WJ
No I didn't... The noise seems to be intermittent....
torchd is offline
post #12 of 29 Old 02-23-2010, 09:29 PM
RobinsonFam1
i fianlly figured out the last of my driveline noises.....the spiders are shot and so is the pin that retains them in place.
the spiders are causing a vibration at all speeds as a wheel bearing would but more of a vibe than a sound.
the pin beaing worn is causing a clacking sound in the rear that is noticeable when the driveline is slack.
so parts came in yesterday and it goes back to he shop on Thursday...ugh
maybe this may help....?!??!?
post #13 of 29 Old 02-24-2010, 12:14 AM
CrazyIvan888
Dumb question here, but you're sure it's not the tires? Tire noise would sound like it's coming from the rear even if all four tires are howling because the rear wheels are right under the passenger compartment.
Jeep: Every adventure is a repair, every repair is an adventure!
CrazyIvan888 is offline
post #14 of 29 Old 03-23-2010, 08:30 PM
bigbill888
Torchd - did you ever figure this out?
96 ZJ Laredo, 4.0, 242, 230K
95 ZJ Limited, 4.0, 242, 140K
98 XJ Sport, 4.0, 231, 140K
All work well
bigbill888 is offline
post #15 of 29 Old 03-29-2010, 11:25 PM Thread Starter
torchd
2003 WJ
I haven't figured it out yet... But now I have a sound that is still in the rear area still that sounds like road noise. Like tires that are mud tires but not that loud....
Any ideas what that could be?
torchd is offline
Pinion bearing? sdog30 ZJ Grand Cherokee Forum 10 08-10-2011 01:38 PM
pinion bearing dirtdogg ZJ Grand Cherokee Forum 7 04-23-2008 07:43 AM
Pinion Bearing Gerald K4NHN ZJ Grand Cherokee Forum 8 09-29-2007 12:11 AM
wheel bearing vs axle bearing. cifer6425 ZJ Grand Cherokee Forum 5 06-21-2007 02:04 PM
Help! Pinion Bearing? akasha ZJ Grand Cherokee Forum 2 07-15-2005 06:54 PM
