*sigh* zj lift... un-answered questions... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > *sigh* zj lift... un-answered questions...
G2 Disc Brake Conversion Kit for Jeep Wrangler YJ TJ LJ ChSavvy Billet LED Tail LightsFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 09-26-2014, 06:54 PM   #1
inkedrockstaar
1994 ZJ
I have a zj i6 42re. right now I clear 31/10.50/15's with no rubbing or death-wobble ( with offset eagle alloys). im looking to do a budget lift.... been considering everything from the 2" bb or f2r swap with 3" spacer up front or a 3.5 lift spring... ive seen a million posts about lifts but none tell me what I need exactly to lift my jeep or how to do it right.... before winter at that... this will be deciding my setup for the next year!
2"bb lift- do you have to do anything other then put the spacers in??
f2r swap- if I get 3.5 springs and swap the front to the rear can I use track bar relocate brackets front and rear? I know I know get a aj track bar. .. I cant afford it yet but id like to eventually. any help or knowledge on the subject would be the biggest help to this newb to the zj world.
inkedrockstaar is offline   Reply With Quote Quick reply to this message
Unread 09-26-2014, 07:00 PM   #2
MurdaJs
At 3.5 stock control arms are ok.
Adjustable trac bars or brackets highly recommended.
Spacers are ok, but not over 2" in the rear. Take a look at your rear spring and you'll see why. Up front, 3" spacers or lift springs will do the same thing, especially if you are on stock control arms
Built one piece at a time, and it cost me many dimes
MurdaJs is online now   Reply With Quote Quick reply to this message
Unread 09-26-2014, 08:01 PM   #3
inkedrockstaar
1994 ZJ
ok thank you. I've seen ALOT of people saying don't use the brackets because of them ripping off the stock bracket? I wont be doing any hardcore off-roading, other then a snowy backyard,or mudding the once a year I go.
so if I get shocks, front and rear track bar brackets, 3" spacer for front, and another set of front coils I would be good to go?
Unread 09-26-2014, 08:10 PM   #4
MurdaJs
There is a lot of leverage on those brackets. Make sure those bolts are always tight as ****.
In theory, you will be good to go. The thing is, lifting, and then bigger tires, puts A LOT more stress on stuff. Wheel bearings, ball joints, steering ends, control arm bushings, driveshaft c/v or u joints; they all will wear down faster, much faster. So if they don't already need to be replaced, expect problems to start showing up.
Unread 09-26-2014, 08:15 PM   #5
inkedrockstaar
1994 ZJ
Much appreciated information.
I am hoping to replace all the tie rod ends, ball joints, ca bushings and u-joints this weekend.
have the parts but never the time.....the struggle is real....
Unread 09-26-2014, 08:22 PM   #6
MurdaJs
Ha! You should see my pile o parts
PB blaster is your friend
