Ok, back in December on a wheeling trip, I hit a tree with my side view mirror and it broke off. One of the plastic ear pieces that holds the rod that the 2 springs attach too broke, allowing one spring to slip off and come loose inside the mirror as well. Now, I took the mirror off the door and put everything back to where is was suppose to be. Well, my problem is that the top spring got streched out so the mirror wouldn't fit tight to the body. Well, I put a band-aid on it by putting some adhesive in between the body and mirror. Well, that didn't hold up to any pressure. Well, in an attempt to fix it again, the top spring came undown again. Now, most mirrors I have seen online are un-painted and close to a $100.
So now onto the question, is there a kit out there that includes new springs for the mirror? If not, does anyone know if all the mirrors on ZJ mount the same so that I could just buy a used, cheap mirror, and get the springs out of it? Or, if not, can anyone recommend a really strong adhesive that would work?
