Side gapping spark plugs? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Side gapping spark plugs?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAwesome Open box items at OPENBOXOFFROAD.COMJeep parts, deals and more at JeepHut.com
Unread 03-28-2015, 04:05 PM   #1
Teslein
Anyone ever experiment with this? I was trying different spark gaps and found a generous 0.07 gap ran the best. Trying to search for others who have tried a large spark gap brought up results for something called side gapping. They cut the ground electrode back to unshroud the center electrode. The theory seems to be by unshrouding the spark it results in a quicker and cleaner burn. I can't see how that would be the result. Maybe I'm wrong, but wouldn't doing this simply result in more reliable spark by exposing it more to the air/fuel mixture?
Teslein is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 02:53 AM   #2
kg6mov
Hears the voices
kg6mov's Avatar
Methinks you would need to index them for that to have an effect. Seems like a lot of work for not a lot of gains.
1996 ZJ Green Laredo V8, 2.5" OME and Bilsteins, 33's, Holes drilled in the roof.
1998 ZJ Platinum Limited 5.9, Backyard parts fodder
kg6mov is online now   Reply With Quote Quick reply to this message
Unread Yesterday, 05:51 PM   #3
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
I've tried sidegapping plugs a few times. Pretty sure it's worth a touch of extra power, but not much. The plugs don't last when you do this because the wear surface of the ground electrode is reduced. But who cares with cheap plugs and they are easy to swap in ZJs. If you care about an extra HP or two and probably a little better mileage, then I don't think it can hurt. It's extra work and you will be needing plugs more often, so you got to factor that in.
HighLonesome is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 09:01 PM   #4
Cbob4
And the question is, when in the powerband will that extra 3 HP be realized? At 5K RPM?
Cbob4 is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 09:23 PM   #5
HighLonesome
You're exposing the spark more to the combustion chamber at all RPMs so I would guess the small gain is across the board.
Unread Yesterday, 09:42 PM   #6
Hexonut
I run AC Delco, they are the best plug I've found for my 4.0
A 3HP net could be anything like the slight difference the testers foot applied the gas pedal on that particular dyno run.
Zombies man, they creep me out...
Hexonut is offline   Reply With Quote Quick reply to this message
