Shuttering - JeepForum.com
post #1 of 33 Old 01-04-2014, 06:48 PM Thread Starter
tucsonzj
Shuttering
So I've had a few suggestions and am trying to get as many minds as possible on this, so all help is appreciated.
So once the temp started to drop I suddenly got a rough idle and a really bad shutter when I'm driving above 40mph and it drops to ~1500rpms on the downshift (not really a specific rpm but runs between 1200 and 1800 or so). So I cleaned the IAC, idle is fixed (90%). But the shutter is still there. If it starts to shutter I can let off the throttle and then get on it again and it will go away, til it down shifts again and the process restarts. I recently started to notice i'm getting some harmonic vibes on the highway, but I had that slightly over the past few years so not sure if that's accompanying or escalating with this problem. So now for the random check engine light, codes 12 (batt disconnect, even tho it hasn't been disconnected, and 35? or whatever the EGR code is. I know my egr is messed up because last winter the check engine light came on, had it check out mechanic said the wires for the egr melted and fused together, but from the last 12 months i've had no issue with it and the check engine light isn't always on (comes on randomly, I turn off the jeep, turn on and light is gone, most days I never get a check engine light, only long drives or when it's freezing a** cold).
So far I've been recommended
-TPS
-Failing Torque Converted
-Engine/Tranny mounts
don't/can't really just go throwing parts at the jeep as I'm poor haha so any advice would be helpful. Thanks
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #2 of 33 Old 01-05-2014, 01:10 AM
JasonStebbins
You have my vote for torque converter issues.
When is the last time you changed the fluid/filter?
Poop
JasonStebbins is offline
post #3 of 33 Old 01-05-2014, 05:26 AM Thread Starter
tucsonzj
Not as long as I've had it. Which has been about a year and half or so
tucsonzj is offline
post #4 of 33 Old 01-05-2014, 09:34 AM
PolkaPower
Its better go by miles.
PolkaPower is online now
post #5 of 33 Old 01-05-2014, 10:05 AM Thread Starter
tucsonzj
I've put about 22k on it
tucsonzj is offline
post #6 of 33 Old 01-05-2014, 10:16 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Solve the rough idle first. Baby steps.
At idle, tap on the IAC. If the motor stumbles or stalls the IAC is shot.
HighLonesome is online now
post #7 of 33 Old 01-05-2014, 10:20 AM Thread Starter
tucsonzj
Idle is pretty much fixed since I cleaned it. It's not perfect but Def not rough anymore. I'll tap on it later just to see if there's still an issue
tucsonzj is offline
post #8 of 33 Old 01-05-2014, 10:47 AM
Jcalloway
Bump for answers. Mine is doing exactly what yours is doing. I'm not jacking the post, just want to be able to find it. Don't know if it would help you, but I'm getting code 43 to.
Jcalloway is offline
post #9 of 33 Old 01-05-2014, 12:04 PM
HighLonesome
http://www.allpar.com/fix/codes/faults/code-43.html
Could be coil, relay, ECM or wiring/connections throwing that code.
post #10 of 33 Old 01-06-2014, 10:32 AM
Jcalloway
I changed out plugs and wires last night. Unhooked my battery for about 30 minutes. Hooked it back up. Cranked it up and it was running like a top. I drove it got up to 55 which is usually around 1500 rpms and it was smooth as silk. I was like heck yeah. Then about 5 miles of driving it started like this stop and go like the engine was cutting out or something. Old problem it was shaking. New problem it's like you keep randomly tapping the brake.
post #11 of 33 Old 01-06-2014, 10:45 AM
JasonStebbins
That's a rare but great feeling.
Is it surging/stalling/sputtering? Lose power altogether or does it just seem like it's coughing?
Poop
post #12 of 33 Old 01-06-2014, 11:19 AM
Jcalloway
I would say losing power for a second at a time. Some times it's really fast in succession. Other times there is about a 3-4 second pause between them. It's like running out of gas I guess. But very fast. Literally feel like your riding a horse. But not shuttering. It was shuttering or shaking. Now it's just maybe stalling. It's not revving up.
post #13 of 33 Old 01-06-2014, 11:38 AM Thread Starter
tucsonzj
While running I tapped on the IAC and no change in the idle. Engine was warm. Noticed the motor is rocking pretty good (I think? never really noticed before) in the bay.
tucsonzj is offline
post #14 of 33 Old 01-06-2014, 11:55 AM
HighLonesome
Sounds electrical to me, but a guess. I would try another coil at this point. And swap out the ASD relay.
post #15 of 33 Old 01-06-2014, 11:59 AM
HighLonesome
Maybe like a miss. I'd check fuel pressure. Then plugs. All the free things
