Shut down while driving but will restart and continue on way - JeepForum.com
post #1 of 3 Old 04-05-2013, 12:40 PM Thread Starter
robdiesel86
My 96 Zj is shutting down while driving but sometimes will re fire and continue driving. I would appreciate any help.
robdiesel86 is offline
post #2 of 3 Old 04-05-2013, 02:57 PM
Uniblurb
Uniblurb's Avatar
Here's a real good list of things to check for stalling problems.
http://www.jeepforum.com/forum/f13/1...talls-1407423/
Are you're gauges going wacky when starting to shut down, particularly the gas gauge and/or voltage gauge? If so you may want to get an ohm meter, set it to the lowest ohm setting, and check the plug at the far back/passenger side by the valve cover to the crank sensor. Put the black meter probe on only the middle B pin (ground cavity) and the red probe on either A or C like in the below directions (same for 4.0 and 5.2). Any resistance at all, it's bad, and only replace w/another Mopar sensor. Good luck.
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 96 4.0 XJ (son's)
Uniblurb is online now
post #3 of 3 Old 04-06-2013, 05:26 PM
mholmes7979
1994 ZJ
Most likely the PCM is getting ready to die. Could be the IAC valve that just needs cleaning.
mholmes7979 is offline
