Should it be THIS slow? - JeepForum.com
post #1 of 18 Old 11-29-2008, 09:27 AM Thread Starter
JrMechanic
Alright alright, I know its not a car, it has low end torque, and isn't made for speed... But now that the steering is taken care of, I got on it a little. 20-50 isn't bad, but 50-60 is slow, 60-70 is excruciating, and 70-80 is non existent. Once it hit 70 it seemed like it almost just plain stopped accelerating and just kinda hummed. Is it just my 3:55's, or does the I6 lack that much top end?
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #2 of 18 Old 11-29-2008, 09:43 AM
93gc40
Let's see, its a 4000lb 4WD suv with a 190hp 6cyl motor, oversized tires, and 3.55 gears. No they are not drag racing vehicles, mine will do over 100mph, but it takes a week to buildup the mometum. Yes the I6 has zero top end. Thats why you have the Z28. Your performance sounds a little sluggish, try a tune-up, check compression.
96 XJ 4.0 / 231 / 3.5" JY Lift/ 31" BFG /.....
93 VT1100 - Harley killer.
97 ZJ 4.0 / 242 / Stock
93 ZJ 4.0 / 2"BB / Wranglers / RIP-Gone but not forgotten.
If it aint dirty, it aint a JEEP, it's just a SUV.
93gc40 is offline
post #3 of 18 Old 11-29-2008, 09:44 AM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
I have no problem gettin my 93 I6 on 31s and 3.55s over 90, though it's not a comfortable sensation, knowing a strong cross-wind could take me out. Never had the guts to fully top it out, but have no doubt it could easily do 105-110 or more...
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #4 of 18 Old 11-29-2008, 09:50 AM
Darthteddy
1955 M-38
Yall are crazzzy to go that fast.
I havent taken the buggy over 65 ever. And usually I dont go over 50.
V8s a different story tho.
Try doing a full tuneup, run some Engine Restore, and see how that goes.
Dylan-19 and Yearning
93 Rubigrand - Sold... :'(
95 Grand Cherokee Limited - 5.2 Mall Crawler
55 Willy's M38a1 - 231v6, 33" Super Swampers, D44 Full Floater Rear, Locked Front and Rear, 5.38 Gears, Viair OBA, Bilsteen 5100 shocks, Dana 18, Turbo 350, S10 Power Steering, Tilt-wheel, Full Cage, Flat Fenders....
Darthteddy is offline
post #5 of 18 Old 11-29-2008, 09:51 AM Thread Starter
JrMechanic
Thats what I stated first in my post. I just think I should be able to get up to highway speeds easier than that. Ignition system is good, and compression is also good.
Im wondering if it's because my cat is going bad? I don't think its plugged, but it has a rotten egg smell. Could it be contribution to the problem?
One more thing, whats the diameter of the cat, in and out?
post #6 of 18 Old 11-29-2008, 09:55 AM
Darthteddy
1955 M-38
A clogged Cat can deff bog down an engine. Try ordering one off Ebay and replacing it. Or to try it out. . .On bolt the cat and see how it does.
"Temporarily" only of course.
post #7 of 18 Old 11-29-2008, 10:01 AM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
If you can smell the cat like that, there's a strong chance that's your problem.
A restricted exhaust sucks your HP in a big way...
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #8 of 18 Old 11-29-2008, 10:12 AM Thread Starter
JrMechanic
Well, whats the diameter of the cat? I'll go get a cheap flex pipe to put in place and see if it helps any.
post #9 of 18 Old 11-29-2008, 10:24 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
I believe the cat is 2.5" in / 2.25" out. Not positive though on the I6.
If it's the stock cat, get rid of it for sure. The factory cats don't flow well to begin with and clog up even more after time. Maybe it's time to buck up and get a cat-n-back from Kolak.
HighLonesome is online now
post #10 of 18 Old 11-29-2008, 10:40 AM Thread Starter
JrMechanic
No emissions requirements where I live, so I am not planning on dropping big bucks for a high flow cat on a 16 year old vehicle when I don't even need it. It had a new cat back put on it about 8,000 miles ago, but its going bad again.
So is it def. 2.5 in and 2.25 out? If thats the case, would I be able to just use a flex pipe?
post #11 of 18 Old 11-29-2008, 10:42 AM
-Joe-
-Joe-'s Avatar
My 4.0 accelerates nicely when I need to do so. Stock air intake, nothing special about exhaust.. Just a ton of miles on it.
I am sure you can find a non-jeep engine to fit in there..
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #12 of 18 Old 11-29-2008, 10:56 AM
HighLonesome
How do you know the cat is going bad?
You can't remove the cat legally Plus when you are crawling offroad, you are the one that benefits from it. And at 8000 miles, it's probably still like new anyways. You can have it checked at a muffler shop.
post #13 of 18 Old 11-29-2008, 11:41 AM
JG_Canuck
Should've got a V8...
Good point. I really doubt it's your cat. Unless you've been running too rich for way too long.
Canadian Jeep Club Member Forty-Two
JG_Canuck is offline
post #14 of 18 Old 11-29-2008, 12:20 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
A cat-back generally means from BEHIND the cat, and back....usually does not include a new cat.....so yes, it could easilly be a bad cat at that milage.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #15 of 18 Old 11-29-2008, 12:38 PM
Jones
Consider the following...
Jones's Avatar
This is why I sold my 4.0L and got a 5.9L, not enough power.
Jones is offline
slow key EZ1 ZJ Grand Cherokee Forum 4 09-20-2007 10:51 AM
Slow on Take-off toke ZJ Grand Cherokee Forum 2 08-22-2007 09:20 PM
4.0 Way TOO SLOW!!! saint777 ZJ Grand Cherokee Forum 5 10-22-2006 02:28 AM
Will an ARB slow me down? parnell5150 ZJ Grand Cherokee Forum 7 09-06-2006 03:59 PM
4.slow... bikemanj7 ZJ Grand Cherokee Forum 14 07-11-2006 01:19 PM
