Should i replace the Governor Pressure Sensor & Solenoid? - JeepForum.com
post #1 of 10 Old 03-10-2011, 11:28 PM Thread Starter
Peterson66
Ok my jeep is a 1997 4.0L I6 with the 42RE transmission. When im driving around i can feel my jeep shifting kind of "hard" mostly coming off of a stop sign or light but i can feel it in later gears to. The jeep has 131k miles on it. I have had the oil and oil filter and air filter changed and am going to do a ignition tune up. but i have no idea when the last time the tranny fluid has been changed or the filter.... but i have read a few threads about some guys replacing the Gov. pressure sensor and solenoid and fixing the shifting problems.... so do you guys think i should do the same? Im planning on doing the fluid and filter while im down there obviously.
found a good price at: http://www.transmissionpartsusa.com/...n_solenoids_se nsors_s/10538.htm
Got the link from a other member on here.
Any input would be much appreciated thanks guys.
Peterson66 is offline
post #2 of 10 Old 03-10-2011, 11:46 PM
jnicewan
Your symptoms are not what the usual Gov sensor and pressure solenoid. Most of these components cause early shifts, 2nd or 3rd gear starts, and/or no downshifts. But as these parts are known to cause problems, I would say you cant really go wrong with replacing them, it could be considered "preventative"
It might be time to consider a simple trans fluid change, while you in the pan, you might check the rear band adjustment. The front band is adjustable externally its on the drivers side of case just above and forward of where the trans shift linkage goes into the trans. Also check/adjust the T/V cable too.
jnicewan is offline
post #3 of 10 Old 03-10-2011, 11:57 PM Thread Starter
Peterson66
How hard is it to adjust the Front/Rear Bands & the T/V cable? Are there any write up's on how to do it with pics/video by chance?
post #4 of 10 Old 03-11-2011, 12:24 AM
jnicewan
I could do a write up, but it might be just as easy for you to search this forum for "band adjustment", there has been a lot of talk/write ups about it. T/V cable has been mentioned too.
band adjustment
If you feel you need to move or just check the adjustment, make sure you mark the cable first so you can at least go back to where it was. A lot of people prefer a cable thats a couple "clicks" tight, for slightly firmer shifts, and to hold gears a little longer before up shifting. Keep in mind T/V cable/pressure does not control the 3/4-4/3 shift.
Where the cable mounts to the bracket at the throttle linkage you will see a white plastic clip, carefully pry that clip up to allow the cable housing to move back and forth. I know some people have also adjusted/bent the bracket where the cable mounts on the trans too for adjustments.
Move the cable housing back (away from throttle body will increase T/V pressure or raise shift points, side affects can also create sensitive downshifts and harsh engagements and harsh upshifts.
Move the cable forward (toward throttle body) will lower T/V pressure or lower shift points, side affects can be early/quick upshifts, no or excessive throttle to make downshifts, slip/shuttle shifts, and slipping trans.
Most typical symtoms of a loose T/V cable would be quick up shifting through the gears, and possible slipping manily during shifts. Along with lack of downshifting under load.
Most typical symtoms of a too tight cable would be, late up shifting through the gears at light throttle, harsh engagements. Also may downshift easily with little throttle input.
jnicewan is offline
post #5 of 10 Old 03-11-2011, 09:37 AM Thread Starter
Peterson66
Any more ideas on what could be causing the hard shifts? I already ordered the solenoid and sensor haha but all well i guess it might help....
post #6 of 10 Old 03-11-2011, 02:33 PM Thread Starter
Peterson66
Bump
post #7 of 10 Old 03-11-2011, 11:00 PM
jnicewan
Trans diagnosis can get pretty complicated without the right equipment. Harsh shifts are usually a pressure related problem or worn components. Have you looked at the T/V cable adjustment? Do your shift points seem right? Will all gears shift harsh or is it just a couple? Does it have harsh engagements like from P/N to R or P/N to D?
jnicewan is offline
post #8 of 10 Old 03-28-2012, 07:23 AM
newberrykc
I've been looking for an answer to my problem similar to this one as well. I DO have harsh engagements from P/N to R and or D. In the morning when I first take off, it will take approx 10 sec to shift from 2nd to 3rd. The engine revs up like it's in N til it actually shifts. Then it almost immediately shifts to 4th. I too will be ording the solenoid and sensor, and will be checking my TV cable today. Any other suggestions?
Don't mean or want to steal your thread Peterson, but I think we are having the same issues....
newberrykc is offline
post #9 of 10 Old 03-28-2012, 01:04 PM
jmonty0523
I just went through this, check for rear o2 sensor codes, if rear sensor is shot, it shorts out 5v supply to tranny...
...________oooo_
/ ./.\...,\_____ \,_____
[_---_______---_\-\\\\\\-\
(o) )-o---) ) (o) )-o---) )______
jmonty0523 is offline
post #10 of 10 Old 01-28-2014, 04:19 PM
RoldGold
Are you sure? When I bought my Jeep, I was driving around with no rear o2 sensor at all. The driveshaft had ripped off the wiring harness. When I replaced the o2 sensor, the transmission didn't behave any differently.
1996 Grand Cherokee Limited 4.0L
PSC Steering Gear; NP249 w/ new VC; Moog TRE's, Track Bar, Stabilizer bar bushings and endlinks, control arm bushings
Still no lift, and almost no paint on the hood
RoldGold is offline
Replace/Repair Governor Pressure Sensor toddplei ZJ Grand Cherokee Forum 9 10-10-2011 02:58 PM
Changed my governor pressure transducer and a governor pressure solenoid but.....? 02Lightning ZJ Grand Cherokee Forum 12 12-21-2009 09:06 PM
tranny flush questions, also governor pressure solenoid cig000 ZJ Grand Cherokee Forum 8 08-29-2009 07:49 AM
Governor pressure solenoid output jeepzj93 ZJ Grand Cherokee Forum 1 06-06-2007 12:49 AM
pressure governor solenoid cyphr ZJ Grand Cherokee Forum 4 03-16-2006 03:47 PM
