Should I replace the front springs? - JeepForum.com
post #1 of 6 Old 11-22-2012, 02:07 PM Thread Starter
jt_armstrong
1994 ZJ
Over the weekend i intend to swap out all the front end bushes and replace tie rod ends, ball joints, steering damper and shocks. I hadn't anticipated changing the coil springs as they "look" ok but given that they are 18 years old and have covered 210K miles should i just go ahead and chnage them anyway? If so are there any recommended brands or at least ones that i should stay away from?
jt_armstrong is offline
post #2 of 6 Old 11-22-2012, 02:13 PM
nicklopic
Old man emu for the springs
98' ZJ 4.0
4.5" short arm, 33" Courser MXTs, custom stubby bumper, skids, someother stuff
nicklopic is offline
post #3 of 6 Old 11-22-2012, 02:15 PM
mike9316
That's about when I changed mine, I'd recommend skyjacker if you have a lift
mike9316 is offline
post #4 of 6 Old 11-22-2012, 02:19 PM Thread Starter
jt_armstrong
1994 ZJ
No lift and i want to keep it stock for now. If i change the fronts should i also do the rears or is that overkill? The rears "look" good as well.
post #5 of 6 Old 11-22-2012, 02:22 PM
mike9316
I didn't have enough money to do all 4 but if you can afford it I would
mike9316 is offline
post #6 of 6 Old 11-22-2012, 02:25 PM
mike9316
I also thought mine looked good until I took em off and found both fronts were broken lol, those were tough country
mike9316 is offline
