should I get a steering stabilizer? - JeepForum.com
post #1 of 6 Old 11-21-2008, 04:26 PM Thread Starter
gharris54
I recently put the IRO 3'' kit and 265 bighorns on my wj with a little over 85,000 miles on it. It is perfectly aligned and there is no shakeing at any time. Since its lifted, bigger tires, should I be worried about death wobble in the future and would it be a good idea to get a new steering stabilizer? I know my stock shocks were trash when I got done with them but how do you know when the ss is worn out?
gharris54 is offline
post #2 of 6 Old 11-21-2008, 05:15 PM
Virmagicus
Virmagicus's Avatar
No reason to be worried about DW. I'd leave your SS and if you do run into DW fix accordingly.
Jeff
Virmagicus is offline
post #3 of 6 Old 11-21-2008, 05:17 PM
CLNinja
CLNinja's Avatar
why spend money to fix a problem that doesnt exist?
you dont have death wobble so save your money ( a SS is just a bandaid to mask the bigger problem anyways)
Matt
**September 2009 Grand Cherokee Of The Month**
CLNinja is offline
post #4 of 6 Old 11-21-2008, 05:21 PM
CMARJEEP
CMARJEEP's Avatar
A SS isn't just to keep your Jeep from getting DW. It also reduces bumpsteer. You will probably find that when offroad, you will have more bump steer than you did because of the bigger, heavier tires. If you are fine with how it is now though then don't waste your money. But a HD SS is a nice thing to have.
CMARJEEP is offline
post #5 of 6 Old 11-21-2008, 10:00 PM
BlackShuck
You should post a couple more pictures now that the new tires are on.
01 WJ Spec. App. Laredo. Retrofitted with Akebono calipers; Stillen Sport Rotors; Reese Class III Hitch; and a ZJ Front Drive Shaft
Save yourself time, money, and a lot of frustration by NOT shopping at JcWhitney!!
Utah Jeep Crew #8
FS: Rear wind deflectors || || Stock OEM Air Box Set Up
BlackShuck is offline
post #6 of 6 Old 11-22-2009, 08:59 PM
jeepgc99lmtd
1955 CJ3A
I am having the same problem. After getting my bigger tires put on I have A LOT more bumpsteer. Would getting a steering stabilizer fix this? If not what should I look for to try and diagnose the problem??
1999 WJ, 4" BDS Suspension Lift, Cragar 342 Series Wheels, Westin Front Brush Guard, 265/75/r16 Cooper STT's FOR SALE!!
1955 Willy's M38A1 Project
jeepgc99lmtd is offline
zj steering stabilizer kidA ZJ Grand Cherokee Forum 19 05-25-2011 08:02 AM
Can't get the steering stabilizer off! Reswob ZJ Grand Cherokee Forum 19 10-30-2009 07:44 PM
Steering Stabilizer Kota04SXT ZJ Grand Cherokee Forum 2 11-01-2008 07:24 AM
Steering Stabilizer Windowsrookie ZJ Grand Cherokee Forum 52 05-31-2008 11:34 AM
steering stabilizer micifus ZJ Grand Cherokee Forum 16 03-20-2007 09:56 AM
