Should I drop my transfer case? - JeepForum.com
post #1 of 7 Old 11-08-2013, 12:43 PM Thread Starter
KoltenZJ
I have a 3.5" lift at the moment and an going to be adding on 2" coil spacers for a 5.5" total lift. I'll also be adding adjustable control arms, and track bars in the near future. Anyways would I need to drop my transfer case running that high? All help is appreciated.
*1997 Jeep Grand Cherokee Limited
3.5" Rough Counrty Lift, 265 75 r16 BF Goodrich All Terrain TA KO Tires
Check out my build thread!
KoltenZJ is offline
post #2 of 7 Old 11-08-2013, 12:44 PM
ELMCZJ95
Nope, not necessary.
Jeep Grand Wrangler Build Thread: http://www.jeepforum.com/forum/f13/jeep-grand-wrangler-build-1398775/#post13935376
ELMCZJ95 is offline
post #3 of 7 Old 11-08-2013, 12:48 PM Thread Starter
KoltenZJ
Really? When would you need to drop it?
KoltenZJ is offline
post #4 of 7 Old 11-08-2013, 12:50 PM
ELMCZJ95
Well I'm currently running over 7 inches of lift and my transfer case hasn't needed to be dropped.
ELMCZJ95 is offline
post #5 of 7 Old 11-08-2013, 01:02 PM Thread Starter
KoltenZJ
My drive shaft feels like it's vibrating already at 3.5" when I'm going about 25-35 mph
KoltenZJ is offline
post #6 of 7 Old 11-08-2013, 01:36 PM
Technohead
Then adjust the pinion angle.
-Eric
Technohead is offline
post #7 of 7 Old 11-08-2013, 02:12 PM
ejschultz
ZJs should never need a transfer case drop as long as you do at least adjustable upper arms to dial in your pinion angles. The transfer case is the part that gets hung up the most on our vehicles. Why lower it making it more vulnerable to hangups?
ejschultz is offline
