Should I Change this Diff Fluid? - Page 2 - JeepForum.com
post #16 of 25 Old 07-17-2011, 09:13 PM
1stblack97ZJ
Add the additives. It might still work, who knows.
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
1stblack97ZJ is offline
post #17 of 25 Old 07-17-2011, 09:14 PM Thread Starter
Newb1995jeepgc
1994 ZJ
Is it really doing any damage if i dont use the additive? Just wanting to save a penny or two.
1995 Jeep ZJ Limited V8- 213k- sold
2000 Jeep WJ I6- 185xxx-sold
1994 Jeep ZJ Limited Red I6- 210k
Newb1995jeepgc is offline
post #18 of 25 Old 07-17-2011, 09:36 PM
Candymancan
addive is only $10 at the dealership... you need 1 bottle
Candymancan is offline
post #19 of 25 Old 07-17-2011, 09:36 PM
1stblack97ZJ
it will if your trac-loc still works.
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
post #20 of 25 Old 07-17-2011, 09:52 PM Thread Starter
Newb1995jeepgc
1994 ZJ
Alright and i guess imma try to find a gasket for the rear housing or can someone explain how i can put that RTV stuff on there or whatever its called.
post #21 of 25 Old 07-17-2011, 10:00 PM
1stblack97ZJ
here ya go
http://www.ehow.co.uk/video_2327974_...l-opening.html
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
post #22 of 25 Old 07-17-2011, 10:17 PM Thread Starter
Newb1995jeepgc
1994 ZJ
Thanks black97zj.
post #23 of 25 Old 07-17-2011, 10:52 PM
Candymancan
Rtv is easy, just put a decent sized line around the cover and bolt holes. Then let it dry for 10 minutes to sorta cure it outside. Then put the cover on and bolt it in a star like pattern.. When you take the bolts off to the cover it wont just pop off either, you need a rubber mallet to gently bang the cover with and itll eventually pop off or get a screw driver and hammer and gently whack the edges and eventually itll break loose. Brake cleaner on the differential gears will help also to clean it up
Make sure you remove the cover and differential of the old gasket material. Use a razor blade or something, and dont scratch it
Oh and fair warning, use cloths that are ripped and stuff that you dont care about. The differential oil STINKS bad and you will never ever get the smell out of clothing.
post #24 of 25 Old 07-18-2011, 07:31 AM
1stblack97ZJ
what are you talking about?
diff. oil smells GOOD!
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
post #25 of 25 Old 07-18-2011, 07:38 AM
speedbucket
its full of water, redo your diff breather (rubber line that should run up over the gas tank)
change out to new fluid in and drive it for a little while, then change it again
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
1st Diff Fluid Change rraiderr WK Grand Cherokee & XK Commander Forum 11 06-01-2011 11:33 AM
Diff Fluid Change biebs53 ZJ Grand Cherokee Forum 16 05-12-2011 02:56 PM
For those who change their diff fluid Passatglx WK Grand Cherokee & XK Commander Forum 1 02-21-2008 04:56 PM
94 ZJ diff fluid change calvin12 ZJ Grand Cherokee Forum 18 02-06-2006 09:24 PM
94 GC diff and TC fluid change ?'s calvin12 ZJ Grand Cherokee Forum 4 05-17-2005 07:51 PM
