Should I Change this Diff Fluid? - JeepForum.com
post #1 of 25 Old 07-15-2011, 11:21 PM Thread Starter
Newb1995jeepgc
1994 ZJ
So opened my diff plug and this ugly mess came out. I have the D35.
1995 Jeep ZJ Limited V8- 213k- sold
2000 Jeep WJ I6- 185xxx-sold
1994 Jeep ZJ Limited Red I6- 210k
Newb1995jeepgc is offline
post #2 of 25 Old 07-15-2011, 11:23 PM
1stblack97ZJ
yumm looks like carmel.
Yeah I'd change it.
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
1stblack97ZJ is offline
post #3 of 25 Old 07-15-2011, 11:28 PM
Candymancan
Looks like water got it in or something... i would change it deff..
One way to know if your diff fluid needs changed is to put some on your finger, let the excess drip off and then count to like 10 seconds if it doesnt drip its still good. But that mess looks nasty. Btw why didnt you use a pan to catch all that ? Or was it coming out of the fill plug ?
Candymancan is offline
post #4 of 25 Old 07-15-2011, 11:29 PM Thread Starter
Newb1995jeepgc
1994 ZJ
Idk why it turned this color hahah its so odd but its needed it for awhile. But autozone nor Advance carries Diff Cover Gaskets anymore so what do i do there.
post #5 of 25 Old 07-15-2011, 11:30 PM
1stblack97ZJ
RTV
a diff. doesn't have any pressure inside it, so you can use RTV sealer as a gasket.
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
post #6 of 25 Old 07-15-2011, 11:34 PM Thread Starter
Newb1995jeepgc
1994 ZJ
Well I did this in a Church parking lot because i smelt something (Pinion Seal gone bad kicking fluid on my pipe) So i opened my diff to see if it was low and this just started pouring out so I took a pic. And I think RTV is what the past owner of my jeep did because its a mess of a seal hahaha
post #7 of 25 Old 07-15-2011, 11:37 PM
Candymancan
If that one looks like that i would check the other one too. Cause that looks like a big puddle of water not oil
post #8 of 25 Old 07-15-2011, 11:38 PM
WhiteOut
WhiteOut's Avatar
I seriously hope you cleaned that crap up after dumping it there.
WhiteOut is offline
post #9 of 25 Old 07-15-2011, 11:41 PM Thread Starter
Newb1995jeepgc
1994 ZJ
I did check the front.. its good and yes i cleaned it up because i kinda felt bad afterwards doing that in a church lot.
post #10 of 25 Old 07-16-2011, 12:10 AM
JrMechanic
That's water in there, which explains why your pinion seal is leaking. That axle will be toast shortly if you've been driving it for any period of time like that.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #11 of 25 Old 07-16-2011, 05:04 AM
melk
google LubeLocker gasket
melk is offline
post #12 of 25 Old 07-16-2011, 07:22 AM
Katesdad
Katesdad's Avatar
Dumping on the church parking lot, classic Im just teasing because removing the plug shouldnt have done that. Looks like lots of water in there to me. Its an easy change.
Katesdad is offline
post #13 of 25 Old 07-16-2011, 05:40 PM
Oldfrog
2007 WK
If you have a trac-lok rear end, be sure and add the additive that it needs, along with the lube.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #14 of 25 Old 07-16-2011, 05:44 PM
gothchick
some of the higher-end gear oils come with the friction modifier already added...
Don't fear the regear.
Finished 4x2 --> 4x4 conversion.
gothchick is offline
post #15 of 25 Old 07-17-2011, 09:10 PM Thread Starter
Newb1995jeepgc
1994 ZJ
My Trac Loc probaly dont work because it has near 190000 miles on it. It probaly needs rebuilt if i did that so do you have to add the additive?
1st Diff Fluid Change rraiderr WK Grand Cherokee & XK Commander Forum 11 06-01-2011 11:33 AM
Diff Fluid Change biebs53 ZJ Grand Cherokee Forum 16 05-12-2011 02:56 PM
For those who change their diff fluid Passatglx WK Grand Cherokee & XK Commander Forum 1 02-21-2008 04:56 PM
94 ZJ diff fluid change calvin12 ZJ Grand Cherokee Forum 18 02-06-2006 09:24 PM
94 GC diff and TC fluid change ?'s calvin12 ZJ Grand Cherokee Forum 4 05-17-2005 07:51 PM
