Should I advance the timing? - JeepForum.com
post #1 of 27 Old 01-30-2014, 05:58 AM Thread Starter
97lerado97
I am having a stalling problem that's been going on for over a month now. It only happens when I come to a full stop a little faster then normal. The idle will also drop very low when I put it in any gear. There has never been a check engine light and many parts were replaced iac, fuel pump filter and regulator alternator and battery plugs wires vac lines..I'm at the point where I want to advance the timing to Give it more gas and see if this helps. Is this a good idea? Has anyone played with the distributor on these jeep. It's a 5.2
97lerado97 is offline
post #2 of 27 Old 01-30-2014, 07:06 AM
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
The timing in a 97 "lerado" is controlled by the computer. The distributor only goes on one way and is not adjustable.
In the garage: M1 4bbl
McCloudsZJ is offline
post #3 of 27 Old 01-30-2014, 07:18 AM
Mickey_D
What you are describing points directly at the Idle Air Control. I know you already had it replaced, but I would investigate it further (wiring, PCM signal, grounds).
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #4 of 27 Old 01-30-2014, 07:38 AM Thread Starter
97lerado97
Wouldn't the check engine light come on if it were any of these? I'm running out of ideas
post #5 of 27 Old 01-30-2014, 09:42 AM
ZeeJay1997
the only way to get the distributor correctly aligned on a v-8 is with a scan tool. you can get it close by the tdc method, but you have to be able to see the relationship between the fuel and spark timing to get it nuts on.
did you clean the idle air chamber when you replaced the IAC?
ZeeJay1997 is offline
post #6 of 27 Old 01-30-2014, 09:58 AM Thread Starter
97lerado97
Yes I cleaned the whole throttle body. This problem is bugging me out. I heard it could be the converter not releasing in time due to some solenoid but they also said if it was failing the check engine would of told me...
post #7 of 27 Old 01-30-2014, 09:59 AM Thread Starter
97lerado97
And the tranny fluid looks and smells fine.
post #8 of 27 Old 01-30-2014, 10:12 AM
PolkaPower
How about the cam sensor or crank sensor? Plenum gasket? Bad coil?
PolkaPower is online now
post #9 of 27 Old 01-30-2014, 10:39 AM Thread Starter
97lerado97
Cam or crank sensor should cause check engine light. The gasket would have had smoke come out when we tested it with the machine. How do you test the coil? I am getting 12 with the battery and alternator
post #10 of 27 Old 01-30-2014, 10:47 AM
chetzar
1994 ZJ
You keep saying it "should" cause a CEL, but it does not always cause a CEL. Plenty of people here have had the Cam/Crank sensor go back without a CEL. Also, you can check the status of your plenum gasket by opening the throttle body and looking for oil with a flashlight, if you see oil, its bad.
chetzar is offline
post #11 of 27 Old 01-30-2014, 10:50 AM
dnuccio
my thoughts exactly. these jeeps are old and not very advanced. i wouldnt be surprised if you cut some wires and the CEL still didnt come on.
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #12 of 27 Old 01-30-2014, 10:52 AM
PolkaPower
I'm just going to say this about the plenum gasket. If it hasn't ever been repaired, it's bad. There are no lucky exceptions to that. It was a factory flaw.
post #13 of 27 Old 01-30-2014, 10:55 AM Thread Starter
97lerado97
Thank you I just needed someone to say it lol. I will replace the gasket tonight...can I check those sensors with a scanner (ethos) or just check the volts
post #14 of 27 Old 01-30-2014, 01:18 PM
PolkaPower
You do know what the plenum gasket is right? Takes several hours do. Best to start in the morning on your day off.
post #15 of 27 Old 01-30-2014, 01:46 PM Thread Starter
97lerado97
Intake manifold gasket...yeah just ordered it should be in tomorrow.
