Shocks-OEM equivalent - JeepForum.com
post #1 of 6 Old 01-15-2014, 05:32 PM Thread Starter
sdjeepguy
Hi Guys,
I have a 1997 ZJ 4.0L with 85,000 miles. I want to replace the factory original socks with something that will provide a similar ride. I don't go off road.
I will be doing this myself but asked the local dealer what they have been using. He said they typically use the Monroe Sensa-trac or Reflex. Anyone have any recent experience with either model?
I understand the Reflex is a little firmer than the Sensa-Trac. How do either compare to what the ZJ originally came with? Thanks.
sdjeepguy is offline
post #2 of 6 Old 01-15-2014, 06:22 PM
ejschultz
ejschultz's Avatar
From what I've read elsewhere, the Sensa-Trac will give you the most factory like ride.
01 TJ - 4.0L, NV3550, 2" Skyjacker budget boost, Xenon flat flares, Trail Gear front bumper, Tuff Stuff rear bumper, RH4X4 sliders, 33" STT Pros on 15x8s
ejschultz is offline
post #3 of 6 Old 01-15-2014, 07:51 PM
txbass06
^^ agreed. Put a set of the sensa tracs on my last truck and they were as close to OEM as I could find. Spoke to a Monroe rep when I worked at a local parts store and he said they were designed to ride like factory
txbass06 is offline
post #4 of 6 Old 01-15-2014, 09:34 PM
Uniblurb
Uniblurb's Avatar
If you do go with the Monroe Sensa-Trac (front-37081, rear-37082) on your 97 4.0 open a free Advance account, order them online, use one of the below discount codes, pick up at the local store, and you'll save quite a bit of money.
Here's the front shocks:
http://shop.advanceautoparts.com/web...cks+%26+struts
Discount Codes:
http://www.retailmenot.com/view/adva....com?c=4582125
At $45/each I'd place 2 separate $90 orders, throw something else in the cart you need for $10 on each order then use TRT41 for $40 off $100. This is one of the better codes, should save you $80, I use it all the time, and good luck!
Note: free shipping on orders over $75 but doesn't apply when you knock the price down below this when using discount codes.
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 93 4.0 XJ (spare), 96 4.0 XJ (son's)
Uniblurb is online now
post #5 of 6 Old 01-16-2014, 02:35 AM
ejschultz
ejschultz's Avatar
I usually do that then use the in store pickup option. That way, I get the good savings and I don't have to pay shipping. What I normally do is add some of the rear hatch stoppers to my cart. I tend to go through those about every 6 months anyhow...
post #6 of 6 Old 01-20-2014, 10:32 PM Thread Starter
sdjeepguy
Thanks for the replies. I did put on the Sensa-Tracs and they do feel like the factory original ride.
shock advice
