Shocking work done, help needed. - JeepForum.com
post #1 of 4 Old 07-28-2009, 11:05 PM Thread Starter
TINTINUAE
I have recently had fitted an RE BB to my 98 ZJ and the twit who fitted it put the rear shocks on upside down. I have read through threads on here and it seems that it is not important which way the rear ones go but I have a lot of bounce when I go over a speed bump in the rear end whereas the front is pretty solid.
Could this be because the shocks are a lot stiffer than stock, or the front compensates for engine weight and control whilst the rear is more for comfort?
I am only concerned coz the shocks blatently say on the bottom "this way up" with an arrow now pointing at the ground
Also if it is an issue will I be able to remove the shocks without raising the vehicle onto jack stands if I support the side I am working on with a jack under the rocker?
TINTINUAE is offline
post #2 of 4 Old 07-28-2009, 11:20 PM
cologc46
cologc46's Avatar
I dont think you will need to jack the car at all to unbolt and turn around the shocks. The weight of the car is supported by the springs, the shocks are just bolted on. If you can get to the bolts, and if the bolts will come loose, then it will be easy job to turn them over. Shocks are pretty much the easiest component in the suspension system to replace, (except the rear shocks on a TJ which require you to drop the damn gas tank to get off).
cologc46 is offline
post #3 of 4 Old 07-29-2009, 05:46 AM Thread Starter
TINTINUAE
Yeah thanks mate. It was simple enough, I swapped them round to be the right way up and now it is great. Feel a lot more ballanced and proper when going over those pesky speed humps.
Only took 45 minutes to do that and straighten out my steering wheel.
All in a lunch hour too, so I am happy.
Cheers.
post #4 of 4 Old 07-29-2009, 07:45 AM
WJ04
For the future...Twin tube shocks have to be mounted the right way, and monotube shocks can be mounted upside down or right side up.
2004 WJ Laredo-selectrac 242-I6- Custom XJ intake w/Amsoil cone filter- PSC HD Pump & Res- PSC ported box- B&M trans cooler- B&M PS cooler- Custom chevy 1 Ton over the knuckle steering- Rough Stuff 1 Ton tierod & draglink ends- Saguaro 4x4 Front 3/4" shackles, Rear hitch & Warn 3/4" shackle-Mopar Front skid,Gastank skid -IRO TC skid- RRO super sliders- 6.5'' IRO critical path lift -IRO extended rear arms-Bilstein 5125 shocks -IRO F&R 6.5'' Bump stops-Carolina drive shaft-16x7 black soft 8's - 34'' Super swampers-Yukon 4.11 gears -Ultimate RCV shafts - LockRight Locked ECGS bolt in rear D60 -35 spline Chomloy shafts -BTF HD diff cover -IRO Adj A-arm-OX Locked super D30 -OX HD diff cover -OX drive away lock-Rock Krawler d30 truss-Stillen rotors & Matrix pads-JKS Adj Track Bar-JKS Quicker discos -Relocated OME SD-40 Steering Stabilizer-BDS stabilizer brackets-Relocated washer bottle-Removed rear sway bar-Cobra CB-TomTom one XL navi-alpine deck
Still to come: Flowmaster 50suv
Some of my videos:
Originally Posted by billyjp2 View Post
I burnout on puppies and kittens
Originally Posted by vwmaniacx View Post
Lets not and say we didn't.
WJ04 is offline
Dana 44 work. Help needed! EisBlade ZJ Grand Cherokee Forum 19 11-09-2009 09:50 AM
Uconnect parts needed to work???? webejpn01 WK Grand Cherokee & XK Commander Forum 4 10-04-2009 01:27 PM
Shocking Thoughts Jaws2381 ZJ Grand Cherokee Forum 5 07-12-2006 08:21 AM
Shocking dilemma anticrombie ZJ Grand Cherokee Forum 5 04-15-2006 04:27 PM
SHOCKING CUSTOMER SERVICE LEON WJ Grand Cherokee Forum 2 07-05-2002 08:53 AM
