shock specs for 4.5in lift on the zj? - JeepForum.com
post #1 of 9 Old 08-12-2011, 03:57 AM Thread Starter
arizonaBRadZj
i have a 1998 5.9L with a 4.5 teraflex lift and my shocks are getting shot. anyone know the specs for the shocks? looking to get something cheaper then ranchos but still works.
arizonaBRadZj is offline
post #2 of 9 Old 08-12-2011, 07:06 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
you don't get too much cheaper than a rancho and still have it "work".
spend the money and enjoy the ride man. black diamond. bbcs, re, procomp mx-6, bilstien, etc.
ratmonkey is offline
post #3 of 9 Old 08-12-2011, 07:51 AM
KingtheZJ
i agree. shocks is something you get what you pay for.
'88 XJ
'98 ZJ on 37s and tons
'02 Chevy 2500HD 8.1
KingtheZJ is offline
post #4 of 9 Old 08-12-2011, 07:53 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
in almost everything there ever was, you get what you pay for.
post #5 of 9 Old 08-12-2011, 11:26 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Probably around 26.5+" extended length. And then as short a compressed length as you can find. Adjust the bumpstops according the compressed length.
HighLonesome is offline
post #6 of 9 Old 08-12-2011, 11:48 AM
ZJFABN
This^^^
Take your shocks off. Jack one tire up as high as it will go before it rubs. (Trim and use BFH as needed) Set bump stop. Then get the longest shocks that you can fit. You want to have just about the same amount of uptravel on your shock as the space between your bumpstop at ride hidth. At full bump you should have about 1/4" of up travel on your shock.
Fwiw, ive had the expensive shocks (Bilstein & Rancho 9000XL's) and now run the $35 Pro comps (in the front) They have a 5/8" shaft. With 35's I cant tell a difference.
I run the Rancho 9000xl's in the rear. I like the adjustability of them for when its loaded down.
My work, http://www.virtualjeepclub.com/showthread.php?70963-JW-Fabrication&highlight=Jwfabrication
ZJFABN is offline
post #7 of 9 Old 08-12-2011, 12:01 PM
PolkaPower
I used to use these. I can' remember that model but they were white. Inexpensive easily replaceable and worked great. http://www.doetsch-shocks.com/
PolkaPower is offline
post #8 of 9 Old 08-12-2011, 12:01 PM
ajmorell
ajmorell's Avatar
It will depend on bumpstopping but that number highlonesome threw out is probably close. I'm running 12" travel Bilstein 5125s that are around 28" extended, 16" collapsed.
ajmorell is offline
post #9 of 9 Old 08-14-2011, 04:19 PM Thread Starter
arizonaBRadZj
Thanks a lot everyone ill give em all a try
alignment specs for WK 2" lift BradMB2004 WK Grand Cherokee & XK Commander Forum 1 02-13-2010 06:33 PM
help, looking for shock specs dmolaver15 ZJ Grand Cherokee Forum 4 03-02-2009 01:49 AM
Stock rear shock specs? 79bigmack WK Grand Cherokee & XK Commander Forum 8 06-11-2008 10:10 AM
What alignment specs for zj with 4.5" lift? bjl95mustang ZJ Grand Cherokee Forum 4 06-15-2007 08:15 PM
Fr. Shock Torque Specs rollerbones ZJ Grand Cherokee Forum 1 05-16-2004 05:53 AM
