Shock Interchange... - JeepForum.com
post #1 of 8 Old 02-19-2013, 04:23 AM Thread Starter
gs69350
Ok, did some searching, could not find an answer for what I am looking for..
Has anyone compiled a list of off the shelf shocks (i.e. stuff available at your local parts store) that will fit a ZJ with different amounts of lift?
I.e. - I have a 2" BB, if I walk into AutoZone, I should ask for shocks for a ____________ for the front and __________ for the rear...
Trying to avoid ordering online, and I get some good commercial rates at the local parts places...
1998 Jeep Grand Cherokee 5.9 Limited - Stone White - Stock for now.
<-- 5.9 Owner's group on FB.
gs69350 is offline
post #2 of 8 Old 02-19-2013, 12:07 PM
BigClay
Why not just measure the length you need and go from there?
Current: 98 TJ, 33" TSLs
Past: 94 ZJ, built for the rocks
BigClay is offline
post #3 of 8 Old 02-19-2013, 12:25 PM Thread Starter
gs69350
Honest answer... I don't know what I need.
gs69350 is offline
post #4 of 8 Old 02-19-2013, 05:02 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
then measure.
ratmonkey is offline
post #5 of 8 Old 02-19-2013, 05:08 PM Thread Starter
gs69350
Lemme rephrase... What do I measure to find the compress/extended length I need? Or do I just take the stock shock off and add 2"?
gs69350 is offline
post #6 of 8 Old 02-19-2013, 08:50 PM
ls1corik
Whatever you do dont use shocks from a chevy silverado! lol I tried cause my stock ones were maxing out, leafspring shocks are different from coil spring shocks so it looked like I was hoppin on hydraulics all through town! bad idea haha, they were new when I started now they are trash. I eneded up ordering some from online.
ls1corik is offline
post #7 of 8 Old 02-19-2013, 08:52 PM
ls1corik
Btw the shocks I ordered for 2-4 inch lift measure at ten inches travel.
ls1corik is offline
post #8 of 8 Old 02-20-2013, 05:40 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Measure distance between shock mounts at full bump. That generally determines the travel you can get away with as there is only so much shock shaft you can fit in a given body length.
